Results 1 to 7 of 7
Thread: tri moto bogs bad
    michigan
    56
    tri moto bogs bad
    Ok guys i really appreciate all the help i have recived so far, that being said....My little 125 tri moto bogs BAD when flooring it. Like in other words when taking off it almost stalls out unless i slip the clutch a little (lift up a tiny bit on the shifter). Then after i get going it bogs bad when shiffting gears. Im thinking the pilot jet and main jet are in order to be cleaned. Does that sound about rite? Also the little fitting on the right side of the carb, what is that? Just a vent? Some retard has a primer hooked to it.
    Baltimore, MD
    6,088
    Your carb probably needs cleaned yes. Without pictures when you tell us soemthing, we cannot confirm what you are talking about. You have to give us a little help/break here if you want us to be more specific in helping you.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Nov 2008
    Coon Rapids, MN
    956
    Try cleaning the carb and setting it back to factory specifications, If that don't work I would check compression.
    Jet needle/clip position - 4E16/3
    Pilot air screw - 1 1/2 turns out
    1982 Yamaha YT125 tri-moto - Boyesen power reeds, YT175 front suspension, Headlight guard.
    1982 Yamaha YT175 tri-moto - Running but ugly
    1984 Yamaha YT 60 tri-zinger - Boyesen power reeds
    My feedback.
    http://www.3wheelerworld.com/showthr...ght=old-yellow
    My album
    http://www.3wheelerworld.com/album.php?albumid=98
    michigan
    56
    I cleaned the carb and adjusted it correctly and it still does it. It has alot of compression so im thinking the idiot who had it before me put to much oil in with the gas. Once you rev it up in neutral it bogs, then clears up and smokes like its running 10:1 ratio haha. So il throw some fresh gas with some klotz benol and see it still does it. Atleast i got the headlight and taillight working, got the chain all set, got the tires to hold air, and degreased the engine. I think im going to get a new air filter to because it has a crappy UNI foam clamp on filter on it, and due to gas getting on it the whole inside is melted.......
    michigan
    56
    forgot to add it runs alot better when the choke is pulled.
    Baltimore, MD
    6,088
    It could be a jetting issues if it runs better with the choke pulled, meaning it wants more fuel. A crappy air filter doesn't help though.
    Nicholson 185s
    michigan
    56
    well i found my problem, the petcock wasnt letting barly any gas out in the on position so i turned it to reserve and it pour gas out now. Now its getting enough gas and it runs great!!!
