Results 1 to 3 of 3
Thread: 81 250r front tire swap question
    Sep 2008
    Wisconsin
    68
    hey guys how can i put a narrower tire and rim on my 81r. if i buy a 85 tire rim and hub off of ebay will that hug fit onto my 81 axle? or would i need a 85 front axle too? how would i go about putting a narrows tire on front?
    Pa.'s Highest City
    8,058
    I think you may have to swap out the whole front end. (triples,forks, brakes..) I'm sure someone will chime in here shortly to correct me if I'm wrong. maybe even a 200x front end???
    Internet
    1,251
    Quote Originally Posted by ToddFrydrych View Post
    You could have an adapter 'plate' made which would allow for a skinnier tire/wheel to be mounted OR you could do a front end swap like I and others have done from a 200x ... (and no ... an 85 tire/wheel/hub won't be a direct bolt on to what you have now)
    Here is how mine looks with a 200x front end ..
    I noticed a dramatic improvement in handling and steering after doing this modification. This was a direct bolt on - only mod's needed are to grind the steering stop down a small bit.
    My next step is to modify my hub to accept a 10 inch wheel to open up many more options in tire sizes.
    A friend over at s.com also bolted up a second generation R front end on his 1st gen R.
    Good luck.
