Results 1 to 13 of 13
Thread: Honda 200 naming
    Apr 2009
    Parker, CO
    607
    Honda 200 naming
    Can anyone tell me about the naming of 200cc 4 strokes. Whats the purpose and differience between the 200s,x,m etc. Thanks
    Sep 2008
    845 New York
    2,302
    200x was the sporty 200 with front and rear suspenions and manuel clutch
    200m had electric start and the 200s was the basic model both were semi auto and hardtails
    1985 Quad Killer
    1985 Mini Raag
    1985 Green Gobbin X2!!
    1990 Kawasaki 300sx
    R.I.P
    Southern MN
    1,875
    The X stands for Cross Country. The S is for "sport". The R is for racing. E would be electric start and if its ES it would have electric start and reverse, and likely shaft drive (the 250 SX and ES big red).
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Mar 2007
    Texas
    5,045
    the es I don't "think" it had reverse (coul dbe wrong as i thought only the 250s had reverse), but it did have a "shaft drive" with electric.
    breakdown.
    200 (82-83) = normal 200 cc pull start trike no front suspension
    200s (83-85) = sport and front suspension
    200e (82-83) = pull start and electric start (pull is backup) hi/low trans chain drive
    200es (84-85) = pull and electric start, shaft driven hi/low trans and some had reverse but i cannot confirm this as i have not seen one myself.
    200x-gen1 (83-85) = (kickstart only) autocross (motocross track style) this was the 4-stroke racer type trike with front and rear suspension. rear has heigth adjustability but depending on the setting can cause the spring to be stiffer.
    200x-gen2 (86-87) =(kick start only) rearest of the 200cc trikes. redesigned engine and rear suspension system, also front is slightly better designed and i think maybe slightly longer travel as well.
    hope this helps.
    ________________
    https://www.mikesatvfix.com
    1984ATC200S's Avatar
    1984ATC200S is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2008
    New Brunswick Canada
    222
    84 200ES- electric start reverse shaft only made one year
    1984 200s
    1984 big red
    1980 Kawasaki Invader 340 liquid
    1993 GMC sierra, 4.3L automatic
    1990 Chev Scottsdale -parts
    1989 Chev wrangler 4.3L 5 speed- parts
    Chevs are for parts GMC's are for driving
    Oct 2008
    NB, Canada
    852
    Quote Originally Posted by oscarmayer View Post
    breakdown.
    hope this helps.
    You forgot the 200m, and the 200es does has reverse.
    200m (84-85) = pull start and electric, chain drive.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
    "Wear Limits Are Just A Suggestion"
    Sep 2007
    100mi west of Chicago
    3,582
    breakdown.
    200 was made 81-83
    200s was made 84-86
    Rob
    Soutwestern PA
    2,040
    200S = Small
    200M = Medium
    200E Big Red = Large
    It couldn't be any more straightforward or intuitive?
    PS. Please don't take this post too seriously - I know this isn't the nomenclature Honda had in mind - but it is an easy way to remember and a nice coincidence.
    While I am at it:
    200S could also stand for "Simple" or "Stripped down."
    200M is "Middle of the road" or "Moderately equipped."
    Sep 2008
    845 New York
    2,302
    ^^^^^^^^^ well put there keister
    1985 Quad Killer
    1985 Mini Raag
    1990 Kawasaki 300sx
    R.I.P
    Apr 2009
    Parker, CO
    607
    cool, thanks everyone.
    Mar 2007
    Texas
    5,045
    thanks for the clearification guys!
    yea i knew i was missing 1. i'm on meds and still not 100%. still getting over walking phenomia.
    ________________
    Aug 2009
    Maine
    30
    Awesome thread.
    Thanks!
    ebecme01's Avatar
    ebecme01 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2005
    NW Ohio
    186
    the ATC200 was made 1981-1983 as stated earlier
    no suspension 1981 or 1982
    1983 did have front suspension and was built very similar to the 200M with the axle in front of the lower legs of the forks.
    the 200S was 4 or 6 inches shorter in length and had a smaller front end with the axle behind the lower legs of the forks.
