Results 1 to 12 of 12
Thread: Getting things ready to start the ATC 70 rebuild!
    Apr 2009
    Oklahoma
    1,234
    Here are some pictures of what I am starting with. Any tips or help would be great! Thank You! I will use this thread for the whole rebuild.
    This is an aftermarket carb anyone know what it is? and can I get a OEM carb?
    Apr 2009
    Oklahoma
    1,234
    This was the sorryest POS Throttle I ever seen I replaced it with the OEM.
    Jun 2009
    Rochester NY
    57
    Were did you get the OEM, I need one!!
    Label everything you take apart.
    Zip tie parts together, take pictures and put seperate components in 1quart and 1gallon baggies. electrical tape crap together too.....
    Go to the post office, get the free "Priority/Flat rate boxes" and keep chit seperate - they're FREE!!!!!!!!!
    Apr 2009
    Oklahoma
    1,234
    CRAP!!! I think my tranny went out, its stuck in 2nd gear like the traanny will not catch gears. its like its in neutrual.
    Apr 2009
    Oklahoma
    1,234
    What should i do?
    Apr 2009
    Oklahoma
    1,234
    What would cause it to do this? I got it back in to neutrual but when put in any gear theres nothing. no sounds just nothing.
    Oct 2007
    Anna, Tx
    165
    check the clutch? is it toast or out of adjustment?
    85 200x
    84 200x-autox
    84 200s--parted out
    85 70
    85 70
    84 70
    69 QA50
    70 trail70
    81 yz250
    82 yz80
    Apr 2009
    Oklahoma
    1,234
    Thank you.
    What would I be looking for in the clutch?
    Jan 2004
    Strongstown, Pa
    548
    Apr 2009
    Oklahoma
    1,234
    Ok i am back i was in for the winter the weather is getting better and I am back at it again. I tried to adjust my clutch from the side screw. Got it back in nutral. but nothing from there.
    Baltimore, MD
    6,088
    It could be many things wrong. It's probably not the tranny though, it's probably in the shifter. First, you really need to get a manual or print out the pages from a manual you can download on line. The Honda manuals usually have a trouble shooting section or sections in them that you will help you out alot. I think your problem may be a piece on the right side of your engine underneath your clutch pack. First you have to remove the clutch side cover. Then you have to remove your clutch assembly. Underneat that you should see where your shifter comes over from the left side of the trike. Now there should be 2 other important pieces to look at. One will be a flat plate with notches in it. Those notches are for the different gears of your trike. Then riding in those notches should be another small plate with a small roller wheel on it. Either the shifter shaft assembly or that small roller wheel is busted somehow. It could be the plate with the notches in it is busted, but I've only ever heard of one of those breaking, but I've never personall seen it. But get yourself a manual. And you also need a flywheel puller and the clutch nut too. Also by looking at the pictures you posted you either have bent forks, or a bent frame and that is why your engine is touching your front fender, but I think it's a bent frame. Post a couple pictures of your frame area underneath your gas tank after you remove the tank. Hope this info helps you. Get a manual!!!!!! LOL Seriously though, get a manual.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
