Thread: 86 tecate flywheel help
    danimal95's Avatar
    danimal95 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    il
    289
    so i thought that i blew the motor this weekend in my 86 T3,but as it turns out,the bolts that retain the lighting coil came loose and it locked up against the flywheel......now here is the delema,some of the magnets are damaged with small pieces missing some are ok,do i have to replace the flywheel or will it still work ok?if i need to replace it what flywheel should i replace it withg that has fixed magnets,not glued on
    2003 banshee ported jugs,piped,yad-ah,yad-ah
    1986 tecate KX5 swap
    1986 350X(cammed ported piped)sold
    1985 250R(310 klemm pipe)
    1985 atc70 x 2
    other toys
    1995 mustang cobra 6 speed twin turbo
    1075 rwhp 963 rwtq
    9.25@156mph
    1992 GMC typhoon 402c.i. LS1
    4L80E AWD twin turbo a/c power steering and cruise
    963 AWHP
    9.40 @ 147 on 4 drag radials
    Jul 2006
    i would think it needs to be replaced but i didnt see it. ricky flywheels work great and will last forever. you can also get the coils from him as well just red lock tite them and you should be in good shape.
    danimal95's Avatar
    il
    289
    Quote Originally Posted by jeswinehart View Post
    And from what i have learned is all of the magnet don't need to be there to work properly.
    Like T-3 Lopes said, maybe a picture might be in order.
    If you would like it refurbished I can do that. Just a couple of advantages of a refurbished one over a ricky is
    - cheaper then buying one.
    These magnets will NOT be affected by water/moisture since it can not get to the glued portion of the magnets.
    These magnets will NOT move, unlike rickys witch you can NOT see move (and they will over time) because of the tin wrap they put on the inside of their fly wheels.
    I was just talking with Lopes about the marketing of these this morning so i apologize for hijacking your thread in a sales fashion but I got to start somewhere I reckon.
    Let me know if i can be of help Dan.
    john
    what kind of money are we looking at?also what is the turn-around?money is alittle tight right now so the cheaper option would work for me....i just had to put 6 injectors in my 03 dodge cummins to the tune of $2800
    1985 atc70 x 2
    other toys
    1075 rwhp 963 rwtq
    9.25@156mph
    963 AWHP
    danimal95's Avatar
    il
    289
    Quote Originally Posted by T3 LOPES View Post
    i figured that,noyt sure ewhy they came loose it was a R/S stator to begin with,i may call him and see what he says,mabey he will warranty it......fyi we are planning a silver lake trip in september,mabey we can meet up again
    1985 atc70 x 2
    other toys
    1075 rwhp 963 rwtq
    9.25@156mph
    963 AWHP
    danimal95's Avatar
    il
    289
    si i just called R/S and they are going to replace the stator and flywheel for me this is the first time a company has actually stood behind their product
    1985 atc70 x 2
    other toys
    1075 rwhp 963 rwtq
    9.25@156mph
    963 AWHP
