Thread: Plug help on 86 250R
    Mobile, AL
    74
    Okay, so im trading in one of my 250r's for a new outboard. When i got to they guys shop, no fire. I checked the plug, real weak, erratic spark. The outboard guy said "i dont know anything about "bikes" but with an outboard you cant run a resistor plug when you need a regular" so he went and grabbed a regular plug (not sure of anything about it) stuck it on there had bright spark. The plug i was using was a BR8ES. What plug would yall recommend?
    By the way i lost all spark 2 weeks ago so i ordered all new Stator, Pulsar, and Ignition Coil and put on some day last week. I havent ran the "r" since. The stator / pulse gen are from RMSTATOR. and the Coil is an aftermarket coil (EMGO) Spelling?? i think thats right. I use there brake pads, their decent. heres a link to one
    http://cgi.ebay.com/ebaymotors/ATV-I...Q5fAccessories
    Should i just try the B8ES? or a hotter plug? colder? i know nothing about plugs and could really use some help.
    May 2009
    alberta
    32
    I'am pretty shure a NGK BR8ES is the proper plug for it. It should have a fixed resistor not one that you can turn off. Make shure your kicking it over fast also and that the plug is a good one. I have bought new plugs before and they wasn't worth the box they came in.
    robb is offline New to the board Arm chair racerNew to the board
    Sep 2006
    bc canada
    63
    try heating the coil up under hot light or something worked for me lon time ago
    Gjoa Haven,Nunavut
    8
    Get yourself a NGK BR8EG and you'll never go back to a ES series plug again,they cost a few bucks more but are well worth it,They foul less,burn better,start easier
