Results 1 to 7 of 7
Thread: Poping out of gear..
    Sep 2007
    California, USA about 50 miles north of sacremento
    976
    85 110 Honda
    Pops out of low/high range. Clutch shifts fine but after a few seconds of riding the transmission slowly slips out of high or low. Any ideas?
    Feb 2009
    michigan
    2,387
    you can try to adjust the clutch,the nut and slotted bolt on the right case.if that dont fix you may have excessive wear on the gears,shift forks.
    1985 ATC 250R
    . Team Red Trike
    nh
    73
    I would bet you have one of 2 possible problems. Either a broken stopper pawl or a broken / loose bolt on the shifting drum. This issue has been discussed before ( many times ).
    Here is a couple links ( with pictures ) :
    http://www.3wheelerworldforums.com/s...17&postcount=5
    http://www.3wheelerworldforums.com/s...ad.php?t=44762
    Hopefully those links will help.
    Sep 2007
    976
    links don't work.
    nh
    73
    When I was a kid my 110 started to pop out of gear, but I think it was the main trans, not the sub. My older brother took custody of the trike, changed the oil, and the problem was solved. Not saying that's your fix, but maybe worth a shot?
    Sep 2007
    976
    Yup, very worth the shot. I will be adding a little lucas to the mix as well. Made my 200s stop slipping..
