Results 1 to 15 of 18
Thread: Identity contest? whats it worth?
    Aug 2009
    florida
    4
    Nice to meet you guys this seems like a good forum!
    I was hoping one of you yodas of honda 3 wheelers could enlighten me with your opinions.
    I sort of got it in trade and I would of gave just about anything t o have it ! It makes me smile -when I look at it I feel like I am 9 again.
    I dont know what cc it is , and i beleive that it has been modified the rear end seems very wide.
    I am 6'3 275 and I am wordering if the thing can even handle me .
    It needs a chain and some good foot pegs they are weak .
    It has been sitting for awhile .
    Sorry all the questions .lol any help would help!
    Attached Thumbnails Attached Thumbnails HPIM6756.jpg   HPIM6757.jpg   HPIM6758.jpg   HPIM6759.jpg   HPIM6760.jpg   HPIM6761.jpg
    83-85 200X, and yes, it is widened.
    Aug 2009
    florida
    4
    so perty slow huh? dang I was hoping for the 250 r but oh well .
    They're still alot of fun.
    Nov 2004
    OH.
    2,487
    SOmeone either put the fork tubes backwards or it may have a 350X front on it. The 83-85 200X's had a trailing front axle. And to answer your question, Stock they are ok, even for someone larger, slightly modified, you can have a blast and get alot of power out of it. Heavily modified, it can be some serious fun.
    Jun 2009
    Hutchinson Kansas
    123
    i have an 84 that is lightly modded and it is a great trail machine. Good easy riding trike, and reliable as all get out. A little maintanance and they run forever. On regular trail riding i keep up with anything, but on open stuff they beat me up lol.
    Sep 2008
    Buffalo
    808
    looks like its got some spacers on the axle. youll see em if you looks on the backside of the rims.
    Tpc 450
    86 250r
    86 350x
    86 200x
    86 250sx
    85 225DR
    (2) 84 YTM
    (3) 85 Atc 70
    Feb 2009
    michigan
    2,387
    she is a 200x 1983-85,seems in decent shape if motor is good and no structual problems,be worth 500.00-1000.00
    1985 ATC 250R
    . Team Red Trike
    springville, PA
    6,185
    It might haul better than you think. If you dig deeper past the widened axle and bassani exhaust (It isnt a FMF) you might just find a bigger carb or motor work. It'll bark even if it doesnt have much bite
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Mar 2007
    Texas
    5,045
    83-85 200x.
    ________________
    https://www.mikesatvfix.com
    Mar 2007
    Texas
    5,045
    Quote Originally Posted by 3wheelintim View Post
    actually you'll be quite supprised. with some tweaks theya re screaming fast!
    here's what ya do:
    performance cam
    performance springs and retainers
    hardened rockers
    performance valve job (got a palce that for $150 labor will clean, and cnc cut the valves and valve chambers for way better flow)
    weisco 12:1 compression piston
    mikuni 30mm carb and 30mm intake (make sure you get several sizes of jets so you can tune it)
    K&N filter
    ebc clutch set and springs
    new timing chain and guides
    new complete gasket set and complete oil seal set.
    that should get you around 18-19.5 hp depending on exhaust system you have and really scream!!! I know I just built 2 of them like this and the guys are still grinning from the performance changes.
    ________________
    Mar 2005
    overton, PA
    5,257
    yea it is a 84-85 200x with a few mods, it has wheel spacers and looks liek ofset rims, and no chain ???????? well theya re god machines and can get pertty good power out of them i am 6 foot and 240lbs and they have handled me just fine. just watch your chain adkistment it shoudl be ok .
    6,798
    Front Forks
    Quote Originally Posted by seadoo650 View Post
    I was thinking the brakes are not installed on the front so they turned the forks around and gain probably 4 or 5 inches in the over all length of the trike . Probably handle a bit better ????
    Mar 2007
    Texas
    5,045
    does it hurt to turn them around? one can always move the break and clutch levers around no biggie, but does it hurt breaking?
    ________________
    Nov 2004
    OH.
    2,487
    They did'nt just spin them around. They put the fork bottoms on the opposite sides. Flipped them I guess. I don't think it would hurt anything but in my experience when this is done it changes the way it handles for the worse. It feels like you have to hold the front from wanting to turn on it's own versus when normal you can let go of the handlebars when moving and it goes straight. I would switch them back to normal.
