Results 1 to 11 of 11
Thread: 350X Fork Seal Replacement
    May 2008
    Tenn
    548
    I recently noticed the bottom part of the blue fork covers were darker than the top part and had oil on them seeping down the forks. I take it that the seals have gone out and was wondering if this will be difficult to fix the seals and how long can it still be ridden before it is damaged to much to be fixed.
    Thanks for any input.
    sheeptender
    Just-Tri-It
    :Trikes Owned:
    1985 Tri-z's 3
    1986 Tri-z
    1984 YTM 200ERN 1
    Mar 2005
    overton, PA
    5,257
    give this guy a call he can rebuild them reasonably his name is al carr 610-367-1700 at reactive suspension he has done allm y suspension work for years.
    Masshole
    2,191
    Its a $15 dollar job with the oil if you do it yourself. They are easy to do. Look in the repair manual, it gives you a step by step.
    Phoenix, AZ.
    6,719
    Bleed the air out of the forks first. Most of the time, leaking oil = blown seals but there's been rare occasions when I would get a trike and find out the previous owner put a bunch of air in the forks. Bleed it out, leak's gone.
    As was stated above though, it's an easy job. The manual can be downloaded for free.
    Jun 2009
    OHIO
    103
    ^ X2 piece-of-cake. Do it yourself and save money.
    devore,ca
    1,055
    Allen wrench and snap ring pliers= done.
    Take the old seal and use it on top of the new seal to tap it in.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Lets not overlook the proper fork seal driver.....
    It's EASY to some guys but this is one of those repairs that allot of people damage the seal merely installing them.
    Seal drivers can be made from PVC or other materials, but you can't just push the seals in by hand or with screwdrivers.
    Jun 2009
    OHIO
    103
    Use the old seal. Put a little bel-ray grease on the lip of the new one. Mine went in fairly easy. Pvc works great.
    May 2008
    Tenn
    548
    Seal Replacement
    Thanks for the input. How much longer could I ride it without major damage? I don't usually ride it hard but I do ride it often. But I don't want to push it too far before I replace them.
    Thanks
    Just-Tri-It
    :Trikes Owned:
    1985 Tri-z's 3
    1986 Tri-z
    1984 YTM 200ERN 1
    May 2009
    new orleans
    65
    x2 on the pvc for a seal driver...use 1 1/2 pvc
    Masshole
    2,191
    If you have acess to a lathe, or a friend with one, you could spin one of these up.
