Results 1 to 8 of 8
Thread: what gearing sould I use???
    Feb 2009
    espanola n.m
    34
    What's up ? I wanted to know what kind of gearing to use? I have a 85 250r and I want to use 18x10x8 tires,but I want the same speed it has. Its all stock I just want to run the tires thanks on any help.
    May 2005
    Southern NH
    1,489
    stock gearing is 13/39...... if you want more top end get a 14 tooth front sprocket, if you want more low end get a 12..... you can start taking away and adding teeth to the rear from there to fine tune it to your liking
    "I have but one lamp by which my feet are guided, and that is the lamp of experience." -Patrick Henry
    NEW ENGLAND ATC owners please join!:http://www.3wheelerworld.com/group.php?groupid=27
    Southern MN
    1,875
    right, to keep the top end speed with 18 inch tires you will definatly want to go up at least one tooth in the front, maybe two (if it fits??)
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Feb 2009
    espanola n.m
    34
    Well I don't race I do a lot of tial rideing I just like the look
    Feb 2009
    espanola n.m
    34
    Apr 2008
    Kalamazoo, Michigan
    814
    Well if it were me, to keep cost down I would go with a 14 tooth front sprocket.
    If that's not enough, like said before drop teeth on the rear sprocket, but rear sprockets are a little more costly
    Southern MN
    1,875
    If you are going to run 18's for trail riding, you better consider ground clearance. I dont know what kind of trails are around you, but around here there is a lot of brush, logs, uneven ground, sticks, rocks, etc. I wouldnt go under a 20'' tire for trail riding, but thats just me, and my riding conditions. Just somthing to consider.....................
    85 Yamaha Tri Z 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    81 ATC 200
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    Bump it up to a 14 in the front..you can run 15T there but it's close, I don;t know if the case saver will fit then...
    TF 07,08,09,10,11,12,13,14!
