Results 1 to 3 of 3
Thread: 85 350x gas and oil problem
    Mar 2008
    Canby Oregon usa
    68
    what would cause gas in the oil.
    i openend up my oil cap today and gas and oil (mainly gas) came out of it and i am stumped on what is the problem the only thing i can think of is the case is crackred somewhere and it runs fine and dosent smoke at all
    85' KLT 110
    ATC 86' 200x
    Nov 2008
    ontario
    1,055
    only thing i can think of is you are leaving your gas on and the gas is seaping past the rings? or the overflow tube is plugged and the gas is draining into the combustion chamber?
    proud owner of a trx300ex quad and an 85 atc 70
    Mar 2008
    Canby Oregon usa
    68
    Could that ruin aything inside the case at all? We ran it for probly 5 min and then discovered that ut other than that it has just been sitting with the gas on for about a week and a half.
    would we have to take the cases apart and have it dry out or just drain the oil then put new stuff in and the drain it again and do that like e or 3 times would that work?
    85' KLT 110
    ATC 86' 200x
