Results 1 to 8 of 8
Thread: Putting a new head on need some help
    Santa Barbara, California
    1,161
    So I got the new cylinder head/rocker head for my '85 200x and am going to put it on this weekend but what should I use to seal the rocker head to the cylinder head? I don't think there is a gasket for it....Gasket sealer? And if so what kind?
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    I've seen guys use the red or blue RTV with good results, but there is a certain one that is recommened that I can't remember the name....someone will chime in.
    TF 07,08,09,10,11,12,13,14!
    Oct 2007
    Grosse Tete, LA
    3,441
    DO NOT OVER DO IT!!!!!
    too many people slather that stuff on....seal an oil passage and consider that top end toast.
    Either of the above will work. I bought a copper based one from the local auto store.
    Feb 2009
    Rome,NY
    1,046
    Quote Originally Posted by The Goat View Post
    +1 on that . put your sealer on real light then wipe almost all of it off and you should be ok
    Jun 2009
    Hutchinson Kansas
    123
    you probably need what is known as gasket eliminator. It is a clear red and is made to seal two machined surfaces together without a gasket.
    I'd go with 3 bond. That stuff is the bees knees.
    Jun 2009
    Hutchinson Kansas
    123
    i think three bond, and honda bond ( i think thats the name) are the same thing as eliminator. If they are, you may be able to get regular eliminator cheaper, not sure though.
    Nov 2008
    ontario
    1,055
    i have yet to use this stuff but i bought it and its suggested for valve covers http://www.permatex.com/products/Aut...et_Sealant.htm
    proud owner of a trx300ex quad and an 85 atc 70
