Results 1 to 9 of 9
Thread: what oil do i put in 81 250r crank case??
    Sep 2008
    Wisconsin
    68
    what kind of oil goesa in the crank case of a 81 250r?
    Aug 2004
    Ab Canada
    4,368
    The "Crank" case runs on the Pre-mix in the Fuel, The "gear" box, you can run some mineral oil-10w40 Men't for bikes, Or some of the fancy bike Gear oil- 75-90 or Close.
    1985 Tri-Z-
    Toronto Canada
    697
    You mean gearbox? I personally just use a decent quality 10w40 motor oil, but many on here swear by Gear Saver
    Mar 2009
    Wake Forest, NC
    80
    You can run ATF in the transmission as well, only in a 2 stroke engine.
    Toronto Canada
    697
    Quote Originally Posted by MTS View Post
    you're a faster typer than I and beat me to it
    Apr 2009
    Parker, CO
    607
    So, nothing wrong with using the gear saver oil? does the heavy weight just cause you to get a little less MPG? No downsides?
    Apr 2007
    I use honda gn4 10w40 in my aircooled 250r's and all my 4strokes too.
    Airfoolers RULE!!!
    Dec 2007
    Quebec,Canada
    1,014
    I ALWAYS use Motul TransOil 10w40....
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    May 2009
    Pennsylvania
    37
    Go to honda and buy Racing Transmission fluid made for 250r's says on the bottle.
