Results 1 to 7 of 7
Thread: 1984-1983 250r brake problem can
    May 2009
    Pennsylvania
    37
    HI , i got a 1984 250r atc that just slows to a stop. Now it does this with the front and back brakes. I have bled the front and rears the traditional way of bleeding and i also used a mityvac to get all the air out. So i know i don't have air in the lines. The resevoirs cups are always filled with brake fluid letting no air in the lines. Ok so I have also greased the sliders and greased the pistons up. The pistons and seals are brand new with no leaking. The pads are brand new galfer pads . I rebuilt the master cylinders so there brand new also. In the master cylinders I have a brand new piston with brand new seals. I'm pretty smart when it comes to all this stuff and can't figure out whats going wrong with my brakes. Why are the brakes sliding to a stop. The bike won't even hold me on a hill like a 660 raptor quad would. the rotor is brand new also i figured that may be it but nope still happening. My main question is could it be that the bike was manufactored to stop like this in 1984? If you seen me i've updated my info. by doing new stuff. I striving for different opinions.
    Dec 2002
    deer park, texas
    2,336
    have you checked to see if the pads are glazed?
    Never argue with an idiot. They will bring you down to their level and beat you with experience.
    Calling an illegal alien an undocumented immigrant is the same as calling a drug dealer an unlicensed pharmacist.
    1981 Wife ( Project)
    Oct 2007
    Minneapolis mn
    4,067
    How much time do you have on the brake pads? Also, what compound are the pads? I know the pads for my motorcycle took a certain amount of time to break in before it would stop correctly...
    Apr 2008
    NW, IND.
    842
    The ones I've riden, 250r's and 350X's the brakes aren't the best, but you should be able to lock up the rear and I could never get the fronts to lock up. Are you sure master is sealed (pinched o-ring)? +1 on rotor glazed. Beets
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    May 2009
    Pennsylvania
    37
    The pads are brand new there made out of sintered metal. No riding time on them at all except for testing.
    May 2009
    Pennsylvania
    37
    The pads aren't glazed i wish that was my problem.
    May 2009
    Pennsylvania
    37
    Wink
    Beets, there are 2 crush washers on each side of the brake line pinched tightly with no leaks.
