Results 1 to 12 of 12
Thread: Paging DC and other SX brains!
    Lewiston, N.Y.
    1,477
    I need to know this info kinda fast but i have the option to buy a 86 250sx rear. Do i need the swing arm or am i ok buying the axle and brake drum and housing. I know the 86 was superior since it prevented the water intrusion the 85 had but what parts would i need. Do i need the swinger or would an 85 swinger and differential work?
    Here is a pic. Will buying this eliminate my water problems? How much would this be worth?
    Dec 2007
    Quebec,Canada
    1,014
    The rear will interchange,the parts on the picture will fit directly on the 85 swing arm,the only difference between 85-86 swing arm is the conception,the 86 is better but do the same job.I have a 86 rear on my 85 sx
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    Lewiston, N.Y.
    1,477
    Awesome! So what would you pay for something like this? The guy told me i could have the swinger and this just make an offer... I dont know what this type of thing should be worth??
    Aug 2005
    Lockport, NY
    2,395
    Jim that thing looks like it has seen better days...
    Jan 2005
    RI
    2,530
    didnt jeff just restore your old one? As long as all seals are fresh and you take care of the rear end youll be fine. Its from the years of abuse that really the rear ends
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Apr 2004
    Brigham, Québec, Canada
    1,528
    Yeah, I don't think the axle should be covered in rust like this.
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    Lewiston, N.Y.
    1,477
    I didnt think it was in that bad of shape. Nothing a little bead blasting couldnt fix. He told me he would take 125 for swinger and rear assembly. However I trust your guys' judgement and thank you! DeePa - yes jeff did but i figured this could be something i could work on for next winter or something. I do want to take my sx out on trails and through ponds but I just know that the 85's are not sealed the greatest and it has got me paranoid.
    Thanks!
    Jim
    Aug 2005
    Lockport, NY
    2,395
    If your going to take it thru water ANY YEAR will be vulnerable. 86-87 is superior sure, but if your going to swamp it and whatever you'll be tearing it down and greasing it a whole lot more often.
    Lewiston, N.Y.
    1,477
    Well im not going to swamp her but playing in ponds and creeks is fun thats all. I will let this one go then. Jeff - called the powder coater about the threads...he said no problem. Should have soon
    Take it thru as much water as you wish, just tear it down every year and inspect it.......
    Unless I'm off my rocker, that axle tube you have there is useless without the 86 swingarm. I didn't think that the 86 brake arrangement could be used on an 85 swinger. The axle, spacers etc are all different.
    It does look like junk anyhow so skip it. Ask Jeff for the NOS one.......
    Lewiston, N.Y.
    1,477
    Thanks for the input steve. I think im going to have sneek over to jeffs house and steal it out of the garage. Its wicked nice.
    Aug 2005
    Lockport, NY
    2,395
    NOS is not going anywhere. But for $1200 I can let her go I guess.
