Results 1 to 15 of 24
Thread: Cam/Cam bushing slighty scored.....
    Santa Barbara, California
    1,161
    So I bought a used '85 Honda 200x that didn't run for a couple of hundred dollars....I bought a new head and carb cause the guy said it needed a valve job and I found a used head with fresh valves for cheap. I noticed when I took the cam out that it did not spin freely in the bushing....I took the bushing off and there is a slight rough spot and a slight rough ring around the end of the cam....I was told I could use some wet sand paper (1000 grit) and maybe sand it to where it spins freely.....Have any of you tried this? Or can you recommend I do anything? I don't want to buy a new cam.....Anyone have a spare 200x motor that runs that they want to sell
    Apr 2006
    Crestview, Florida
    2,429
    I've done that several times, you do need to find out why it wasn't oiling though. Did it have silicone on the head or rocker box?
    Rides
    85 ATC350X
    85 ATC200X
    1,161
    Ok is there a certain grit sand paper to use or anything? I've never done this before on a motor.
    There's nothing wrong with using some 320 grit to get it rolling and then some 600 grit emery cloth (with gas or WD40) to smooth it the best you can.
    Machining and other options are out there, but not cheap.
    Clean it up, smooth it up and bolt the crap together and get a 3 stone brake hone with some lubricant - thats the best way.
    I've seen many of those journals beat up, you lose oil pressure and the cam chain is a bit noisier but they still run fine
    1,161
    Ok and should I just focus on the rough spot or go around the whole bushing/cam? I hope to get this thing running asap haha.
    I would attack the rough spot, then lightly hone the entire journal.
    I think the biggest issue is that the cam chain pulls on it and if the oil level is low or the oil tired, the cam journals suffer.
    The XR200 I rebuilt recently, I had about .080 up and down movement. Which makes it impossible to ever get it quiet and the valves tightened up.
    Baltimore, MD
    6,088
    So you don't want to buy a cam, but you would buy an engine? That is some funny stuff right there!
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    1,161
    Why would I buy a cam when I can get a whole running engine for a couple hundred bucks that is some funny !
    Jan 2005
    RI
    2,530
    you can find a cam for around 20...
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Apr 2006
    Crestview, Florida
    2,429
    i've got a nice rocker box and head for $20 each plus shipping
    Rides
    85 ATC350X
    85 ATC200X
    1,161
    Is it safe for me to start the motor without the exhaust? The double sided studs are impossible to get out of my old head.....Anyone know if I can just go to the hardware store and get a couple of bolts that will fit?
    Apr 2006
    Crestview, Florida
    2,429
    Just starting it for a "test fire" wont hurt but dont ride it much like that. You should be able to use some short bolts without any problems.
    Rides
    85 ATC350X
    85 ATC200X
    1,161
    Quote Originally Posted by Erics350x View Post
    I have the header but no exhaust, gotta find one for sale.
    Apr 2006
    Crestview, Florida
    2,429
    You'll be fine then, you might wanna keep an eye on anything near the outlet though.
    Rides
    85 ATC350X
    85 ATC200X
    1,161
    I wet sanded the cam and bushing and they spin freely now! Thanks for the help, we'll see if she runs.....
