Results 1 to 10 of 10
Thread: black insides?
    85200xrider's Avatar
    85200xrider is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    Cranston RI
    293
    black insides?
    i pulled my motor apart yesterday because i had a couple oil leaks. It turned into me needing a new piston and valves too....my question is...the whole inside my motor is black......almost like it was spray painted...is this normal? all the pictures ive seen people post on here of the insides of their motor was shiny......and if its not normal...whats the easiest and most cost efficient way to get rid of it? im on a budget with a limited amount of tools
    May 2009
    Brampton, ontario
    686
    lol its going to be a big joke is some one painted inside the cases.
    Looking for some smaller style tires like the r's have, just 2 back tires. pm please.
    Apr 2004
    Brigham, Québec, Canada
    1,528
    Post pictures, hard to tell just by your description.
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    Feb 2009
    Rome,NY
    1,046
    what happened to the lifan motor?
    Who cares if it's black. Once you go black - well, you know.......
    As long as it doesn't flake off, whats it hurting besides your ego
    Mar 2007
    Texas
    5,045
    the black coudl also be burned oil as it was always ran low on oil and never proeprly changed. i seen this a coupel of times on a trike. looked to be almost painted but when cleaned it came off, jsut took a while. i ended up using the cases, gearing and repalcing every bearing, gasket, seal and soft component for the guy. oin the end it costed him about $980 in parts and labor. took a long while to clean too.
    ________________
    https://www.mikesatvfix.com
    Baltimore, MD
    6,088
    I've seen some internal honda engine cases and covers that had oversray on the insides. But in those cases, not all of the insides were black. I know some people who build high performance engines often use a coating on the inside of their engines to help with the oil returning to the oil pump faster but that coating is usally a dull red color not black. I think your engine just needs a real good soaking in a parts degreaser tank or maybe a nice steam cleaning.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Personally, I like them pink inside
    Feb 2009
    Rome,NY
    1,046
    +2 on that!!!
    Feb 2009
    Cranston RI
    293
    Quote Originally Posted by AutoXer View Post
    i ended up spendin the money on a 85 tri-z instead haha...so now i got both....
    ill post pictures later........im done for the night.... i did notice whatever it was came off with aircraft stripper ( i was using it on my clutch cover and kicker gear covers so i could polish them) and a little got on the inside and it came off
