Ok I know i'm not stupid but I love this forum cause you can get peoples opinions. So here in Pittsburgh, Pa. it rained yesterday heavy, The puddles on the trail were huge. So i figured blaze real fast right through them with my 1984 250r ATC. My bike starting missing while I prayed to make it close to home as possible. I just held the gas in steady while it mis-fired. Then in seconds I had a complete SHUTDOWN of the engine. The only thing I could think of is the ignition wire that connects to the coil pack and connects to the spark plug boot. "The ignition wire has a crack 360 degrees all the way around just hanging on by the steel wire internally. It was Drenched in water. I took my riding shirt and dried it up which is good cause it soaks water up like a SHAMWOW! LMAO. So when it was wet I kicked 100 times with no response. When I dried the wire off the engine Fired right up!. So do you think the ignition wire is my problem? The water had no time to evaporate of other parts of the electrical system it was Drenched.
See I notice on website you buy parts on, the wire is sealed at the end with a seal and the rubber spark plug boot is the other sealing agent. So the crack I have "breaks the seal" water got on there and KAPOW the engine started mis firing.
