Results 1 to 8 of 8
Thread: 86 tecate clutch pushrod
    Mar 2005
    ma
    988
    anyone know how long the clutch pushrod is? i think i have one from a 84-85, as its not even close to touching the pressure plate.
    anyone know if i can still buy a new one?
    Billet Triz 250 parts, Case Savers, Engine Mounts, Boost Bottles, Oil Caps, and Shifters, pm me for info
    Shock Rebuilding, PM me for details TRI-Z Shocks rebuilt too
    My Feedback
    http://www.3wheelerworld.com/showthr...k-for-sblt500r
    Jan 2004
    Palmetto,Florida
    2,300
    hey Brother.. ask Ed ... up there in In. Tecate-z .. he might know ?
    "07" DR650 Suzuki Dual Sport
    hondawasaki's Avatar
    hondawasaki is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2008
    Murray, UT
    319
    Hey I have 2 motors, and probably a whole bunch of other stuff you need, and I need 2 shocks rebuilt, I P.M.'d you a few months ago, but I'm ready to act now.
    BTW when I ship you my shocks, trade or not I'm going to put the tecate manuals on cd and send them too.
    Oswego NY
    1,935
    I had the same problem w/ my 87 T3. if i put the basket on w/ the motor in gear the basket would not sit all the way into propper position, the rod was to short. I even tried to shim the rod to make it work, once in neutral using a basket holder everything worked fine.
    MIK6 / Mike
    New England Ride 4/13
    Sep 2005
    MICHIGAN
    2,027
    84-85 push rod will not work. I had a similar problem with 86 motor but found someone lost the proper ball bearing that goes between push rod and push plate (not 2 be confused w/ pressure plate).
    I used a ball bearing out of 84-85 and compared the rods.
    I have a rusty one I can measure tomorrow.
    86 T3
    84 T3
    86 KX250
    Mar 2005
    ma
    988
    the push rod i have is 6 1/4 long.
    i'm gonna have to look at it again, i put the engine away, figuring i had the wrong parts. i have a push rod from a newer kx i was thinking of cutting down, but i must have something else wrong.
    how many fiber plates should there be?
    maybe its in gear, i'll check that.
    My Feedback
    Sep 2005
    MICHIGAN
    2,027
    84-85 is 6.25" but the 86-87 is little bit less than 6.5".
    86 T3
    84 T3
    86 KX250
    Mar 2005
    ma
    988
    thanks for measureing them. i made a longer one from a newer kx250 push rod.
    the original one i have must be really worn or a 84-85 rod.
    My Feedback
