you need the ohm meter. and the manual will tell you what the meter should read. i would use a compression test tool. there handy to have if you plan on working on any engine. and there not overly expensive for a tool. im not sure if the big red had a compression lever if it does dont use it pull it with the plug in. if its insanely hard to pull its got decent compression,
