Page 2 of 2 FirstFirst 1 2
Results 16 to 29 of 29
Thread: No spark - 200e
    Apr 2006
    Crestview, Florida
    2,429
    Did you weld the case? It sounds like a bad ground to me.
    Rides
    85 ATC350X
    85 ATC200X
    juggaloclownz18's Avatar
    juggaloclownz18 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    The woods of 315 - NY
    303
    I tried looking for the ground on the frame, but could not see it, i really didn't have the time, so ill have to look tomorrow, where is it located?
    When i went back like an hour later to check some more things, i got a different reading off of the same 2 wires for the kill switch... ODD
    No i never had it welded just did the JB weld for now, trying to save some cash flow...
    85 ATC250r (been waiting way too long!!)
    Tusk Hand Guards
    DG full exhaust (want different one)
    TAG handlebars
    +4 LSR axcaliber axle, carrier, hubs
    FMF Carbon Fiber reeds,
    K&N Filter/air box lid removed
    Motion Pro Twist Throttle
    Pro Armor Tether switch
    Seal Savers - long version
    23" Dirt Devil front - 22" holeshots back
    Soon to be ported/polished (got the work setup on trade)
    Feb 2009
    Rome,NY
    1,046
    the ground is under the tank ... it is bolted along with the coil
    Minnesota
    31
    Ever figure it out? I seem to be having the same problem.
    Feb 2009
    303
    Naw, i had the whole family thing going on all weekend, it was one thing after another, so ill be taking a look see tomorrow some time!! I saw the ground screw and it looked fine other then being dirty, but i had no issues with it running before i took it apart... Im getting very irritated! This isnt my first time fixing my machines either
    Tusk Hand Guards
    TAG handlebars
    Feb 2009
    303
    Well i retested everything and the only thing that does not check out as far as ohm readings go is the stator... According to the manual it is supposed to read betweek 100-400ohms and mine read 000.1ohms....
    That would mean its bad right? Everything else is in spec range, but how would this go bad just being unplugged and set aside to fix the hole in the case, and this would cause a loss of spark right?
    Tusk Hand Guards
    TAG handlebars
    Feb 2009
    303
    Anyone live near me, that has one i can test on my machine?
    Tusk Hand Guards
    TAG handlebars
    Apr 2006
    Crestview, Florida
    2,429
    What exactly did you unhook or remove thats electrical related?
    Rides
    85 ATC350X
    85 ATC200X
    Feb 2009
    303
    Well before i lost spark, nothing other then the stator when i took the side cover off to fix the hole in the case, and make a new gasket, but i was super extra careful of the stator when i took it off... I never got the fly wheel off so i didn't touch anything behind that...
    Since then i have tested every electrical connection and quadruple checked there all fine, only unhooked them one at a time so i know those are all fine, and the readings were good on everything but the stator, that was supposed to be between 100-400ohms and only read 000.01ohms...
    Do you think something could have "worked loose" inside the stator like all those small wires that are wrapped around it etc etc...?
    Tusk Hand Guards
    TAG handlebars
    Mar 2007
    Texas
    5,045
    it's possible. whenthey die, they jsut quit. i had a stator die on the middle of a trail once. that's a tuffy to troubleshoot on the trails let alone fix. lol.
    ________________
    https://www.mikesatvfix.com
    Feb 2009
    303
    Damit, anyone know where i can get a cheap one other then from eGay for $65?
    I know from now on, my multi-meter will be a necessary part of my tool kit ;-)
    Tusk Hand Guards
    TAG handlebars
    Feb 2009
    303
    Do i need to replace the whole stator or would it be just the "stator primary coil" which is located inside the stator with the other ones?
    Tusk Hand Guards
    TAG handlebars
    Feb 2009
    Rome,NY
    1,046
    the exciter coil is about $20 shipped ... not a huge deal ..... pull the fly wheel and solder it in
    Feb 2009
    303
    Well after careful sober inspection of the stator again, i realized that the "primary stator ignition coil" inside the stator is defiantly fried out, at least i feel better knowing what the issue is, now to buy another one :-)
    Tusk Hand Guards
    TAG handlebars
