Results 1 to 10 of 10
Thread: cheap tricks to get flywheel off ???
    greythorn3's Avatar
    greythorn3 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2007
    ALASKA
    302
    Question cheap tricks to get flywheel off ???
    I need to get the flywheel off my 84 R so i can replace the stator for my ignition to have spark.. i dont haev the tool to remove it, is there any cheap tricks to get it off? like prying and hitting it with a or something?
    Ray
    1985 big red 250es working good. 1983 200e waiting for new crank and rod. 200x project looking needing everything.
    michigan
    56
    isnt gonna do it. Spend the 15 bucks and get the puller so you dont screw somthing up. If you had a gear puller those work just be carefull. Good luck
    greythorn3's Avatar
    Aug 2007
    ALASKA
    302
    Quote Originally Posted by bansheejoel View Post
    i do have a 2 jaw gear puller.. maybe i should try that.. also have a steering wheel puller!
    Sep 2007
    100mi west of Chicago
    3,582
    Does the 250R have a flywheel that needs a jaw puller or you do you thread a bolt into it to push it off?
    Rob
    May 2007
    Coshocton, Ohio
    1,815
    You need to get a flywheel puller or you will be replacing the stator and the flywheel.
    Appalachian American Racing
    the home of
    Southern MN
    1,875
    ^ the puller uses the reverse thread to thread into the flywheel center, then you hold that part with a wrench and turn the center bolt it, and POP there she goes. Get the puller and do it right the first time around!
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Lots of guys just put a punch on the crank shaft and with one big hit - WHAM! sometimes it comes off...
    But - THAT is the worst thing you can do, that is if you haven't already done that It puts side force on the main bearings and immediately damages them and shortens there life.
    Get the right puller, it will pay for itself 10X over. If it is the LH thread puller like the 85/86R have, make sure to get a small wire brush into those threads and get off any corrosion. Then oil all threads of the new puller and thread it in until it is nice and tight, not just snug!! Those threads are super fine, sharp and strip verrrrry easy. Do it once, do it right.......
    Never whack any shaft with bearings installed on it unless you plan on changing them
    Sep 2007
    3,582
    Ok so it is like the 200x. I had to take mine off to change my timing chain.
    Rob
    greythorn3's Avatar
    Aug 2007
    ALASKA
    302
    i will order the puller, thanks guys, anyone have a part# for the puller?
    Feb 2009
    Rome,NY
    1,046
    If it is the same as a 200x a axle bolt will work 28-282 $14.99 dennis kirk
