Results 1 to 11 of 11
Thread: ATC 200 no spark need help
    Aug 2009
    terre haute IN
    19
    i just got a 83 200 basket case. rewired it new plug, plug boot and coil wire. ohmed out coil, pulse generator, alternator, and checked and set air gap. tryed two different cdi units (dont know if both are bad) still no spark
    Aug 2009
    terre haute IN
    19
    checked cdi units checked out ok still no spark
    May 2009
    Brampton, ontario
    686
    check ground for your coil.
    Looking for some smaller style tires like the r's have, just 2 back tires. pm please.
    juggaloclownz18's Avatar
    juggaloclownz18 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    The woods of 315 - NY
    303
    Check your stator, mine just crapped out, and i lost spark from it...
    85 ATC250r (been waiting way too long!!)
    Tusk Hand Guards
    DG full exhaust (want different one)
    TAG handlebars
    +4 LSR axcaliber axle, carrier, hubs
    FMF Carbon Fiber reeds,
    K&N Filter/air box lid removed
    Motion Pro Twist Throttle
    Pro Armor Tether switch
    Seal Savers - long version
    23" Dirt Devil front - 22" holeshots back
    Soon to be ported/polished (got the work setup on trade)
    Apr 2006
    Crestview, Florida
    2,429
    unhook the kill switch and try again
    Rides
    85 ATC350X
    85 ATC200X
    Aug 2009
    terre haute IN
    19
    still no spark
    Aug 2009
    terre haute IN
    19
    i have no clue whats wrong
    Apr 2006
    Crestview, Florida
    2,429
    Is the rotor turning when you crank it over? Sometimes the drive pin falls out. I'd start testing the harness and checking the connections.
    Rides
    85 ATC350X
    85 ATC200X
    Apr 2006
    SE CA Dez in the sandbox
    900
    Start backward from the spark plug, wire by wire, connection by connection with a ohm meter. Just did that with my 350x, and even the cdi unit appeared to be ok, it's the only thing that could be bad at this point.
    I metered three different 1985 cdi units like the manual shows and none of them were really the same. Just have to change it out and see if it works.
    Have '85 350X-XR500 Hybrid,
    Had Nicholson framed: 90/110, 185s, Gen I 500, Gen II 500
    Had Bandito Framed 90
    Have Vey's Framed 90
    Have too many parts
    Pafrig's Avatar
    Pafrig is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2009
    ALASKA
    278
    do a continuity test between the red/black wire coming from the alternator, to a known ground. if its good, starting checking wire continuity. Chase electrons till you find it.
    Aug 2009
    terre haute IN
    19
    thanks i'll try in the morring
