i just got a 83 200 basket case. rewired it new plug, plug boot and coil wire. ohmed out coil, pulse generator, alternator, and checked and set air gap. tryed two different cdi units (dont know if both are bad) still no spark
checked cdi units checked out ok still no spark
check ground for your coil.
Looking for some smaller style tires like the r's have, just 2 back tires. pm please.
Check your stator, mine just crapped out, and i lost spark from it...
85 ATC250r (been waiting way too long!!)
Tusk Hand Guards
DG full exhaust (want different one)
TAG handlebars
+4 LSR axcaliber axle, carrier, hubs
FMF Carbon Fiber reeds,
K&N Filter/air box lid removed
Motion Pro Twist Throttle
Pro Armor Tether switch
Seal Savers - long version
23" Dirt Devil front - 22" holeshots back
Soon to be ported/polished (got the work setup on trade)
unhook the kill switch and try again
Rides
85 ATC350X
85 ATC200X
still no spark
i have no clue whats wrong
Is the rotor turning when you crank it over? Sometimes the drive pin falls out. I'd start testing the harness and checking the connections.
Rides
85 ATC350X
85 ATC200X
Start backward from the spark plug, wire by wire, connection by connection with a ohm meter. Just did that with my 350x, and even the cdi unit appeared to be ok, it's the only thing that could be bad at this point.
I metered three different 1985 cdi units like the manual shows and none of them were really the same.Just have to change it out and see if it works.
Have '85 350X-XR500 Hybrid,
Had Nicholson framed: 90/110, 185s, Gen I 500, Gen II 500
Had Bandito Framed 90
Have Vey's Framed 90
Have too many parts
do a continuity test between the red/black wire coming from the alternator, to a known ground. if its good, starting checking wire continuity. Chase electrons till you find it.
thanks i'll try in the morring
