The kicker on my 85 200x has a broken return spring. Shortly after this issue came up, when i tried to start it the starter position seems to shift and the lever will only come about half way back up and it makes kind of a slight crunch noise and skips. I have read about the skipping issue with these starters and was wondering if maybe the gears inside have broken some teeth and are moving the position of the whole unit. sorry if you are having a hard time understanding, its hard to explain. Thank you for any help
