Thread: yamaha yt 175
    Aug 2009
    Boise Idaho
    yamaha yt 175
    I need help ....I have a yt 175 ...having issues when you go into 4th 5th gears 3/4 -full throttle it starts to cut out like it has no gas . we changed the main jet everything is adjusted acording to specs still having the same problem .when idiling you can open full throttle no issues. Can somebody out there give me some help fiquring this out give me some input
    Aug 2009
    yo more air?
    Dec 2013
    Deer Park, WI
    53
    I'm having the same issue
    Wichita, Kansas
    1,359
    check the fuel pump, do a leak down test on the machine. Make sure your air filter is clean. You may also need to clean the pipe out.
    Revived a double dead thread. WOOT!
