Results 1 to 15 of 23
Thread: Tri-z lower stem bearing help...please!
    Apr 2009
    Mississippi
    42
    Question Tri-z lower stem bearing help...please!
    I'm trying to get this up to a rolling chasis but I'm stuck at getting the lower race out of the steering stem. I searched but couldn't really find anything definitive. I've tried to get a punch or even a long screwdriver to catch a lip so I can pound it out, but no success. Next I tried to cut it into pieces with a dremmel in hopes that I could get a punch on one of the cut notches. Still couldn't get that to work. Anyone have any ideas on how to get this out?
    I've attached some pics of the frame upside down so you can see the race.
    Thanks for any ideas as I'm all out at this point
    Attached Thumbnails Attached Thumbnails DSC00085.JPG   DSC00086.JPG   DSC00087.JPG
    Jan 2005
    RI
    2,530
    when dirtcrasher removed mine he took a dremel with a gridning wheel and made a notch in the head tube just above the bearing race so he could get a punch down onto the race and drive it out.
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Apr 2009
    Mississippi
    42
    No worries about that weakening the head tube? Have you had any issues?
    Thanks for the help too
    Frewsburg NY
    1,169
    Torches! heat the race up and it will shrink enough that you should be able to break it loose.
    May 2009
    Brampton, ontario
    686
    i buy cans of Co2, heat up the head tube and race. when there both nice and hot. spray the co2 (kinda like frozen air) directly onto the peice of bearing thats stuck. it will get cooled way faster then the head tube. and in most cases you can hear it crack loose. and it should just pop out.
    Looking for some smaller style tires like the r's have, just 2 back tires. pm please.
    Quote Originally Posted by johnny's X View Post
    If he heats anything it would have to be the stem, not the race. Heat expands metal, cold contracts it.
    Quote Originally Posted by Lukeatc185 View Post
    Not a bad idea.
    May 2009
    Brampton, ontario
    686
    the co2 cans i buy have the tube from the nozzle like WD40 cans have. so you can easily cool just the bearing peice. i use it for any locked metal on metal.
    Apr 2009
    Mississippi
    42
    That co2 sounds like a good idea. Where do you get those cans of it?
    May 2009
    Brampton, ontario
    686
    i get them at computer places. the stuff to blow out your keyboards.
    Frewsburg NY
    1,169
    i was thinking heh would let it cool and the race would shrink
    The notch I ground was teenie tiny and there wasn't another way we could think of....
    I'm starting to forget all the chit Mike and I worked on
    Aug 2002
    NY
    2,652
    Why were you trying to remove it in the first place?
    Southern MN
    1,875
    Another way would be to bring it to a machine shop where they have a BIG drill press. They would have to use a really big drill bit, but with any luck they will have one that size. You would be suprised how easy the drill would take it out. I had to have somthing like that done once, and it only cost me $20. I tried heating it, beating the piss out of it for two hours, making a puller, and no go, so I gave in, and the drill had it out in 5 minutes. Good luck.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Aug 2005
    Lockport, NY
    2,395
    For all you Rookies...
    This is what the pro's use.
    http://www.motorcycletoolchest.com/P...1_2_p/rt-1.htm
