what type of oil would be a good type to run in my 85 350x
Honda Brand 4 stroke motorcycle oil. 10w-30 or 10w-40, your choice. If you dont want to use the Honda oil just make sure whatever you pick is for motorcycles. Car oil isnt made for our clutches nor is made to be constantly mashed like in our transmissions (breaks down much quicker)
Here is what I use and recommend. Honda GN4 oil which I get from my local honda dealer. I use the 20w-50 and it is a good quaily oil. May be alittle more money but it will only make you engine last longer and what is recommended for Honda ATCs/ATVs. You can use pretty much any oil that is considered "motorcycle oil" Regular motor oil is not designed for wet clutches.
http://powersports.honda.com/accessories/parts.aspx
then click 4 stroke
DIESEL rated 30w or 10-40w. Car oils are made different now. Diesel rated oils
still have the good stuff in it.
YAMAHA 450 HYBRID
85 350X- RED
85 350x -BLACK
86 350x-WHITE (with Goki)
85 250r
83 atc 70
84 atc 70
84 atc 110
09 yfz 450
2006 Arctic Cat Prowler
RZR XP 900
i have always used pensoil 10w-40 it's yellow metal safe and works fine with clutches.
________________
https://www.mikesatvfix.com
