Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
Thread: My 350X spark problems have returned.
    I'm very glad to hear that someone is helping HD
    I mentioned this before - The 350X runs with the kill/lt switch removed at the main plug. "OFF" grounds out the circuit, so unless it won't shut off - cleaning the handlebars and the contact will not make a motor run....... If it's unplugged completely, it can be ruled out.
    HD mentioned the VR too - the voltage regulator has no effect on the spark. It regulates voltage to the head and tail light, thats all.......
    Apr 2008
    NW, IND.
    842
    +1..... On/Off switch or CDI. Hope you get this electric gremlin Hoosier, at least you got to ride it for a bit. DON'T give up!Good luck Beets
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    Apr 2006
    SE CA Dez in the sandbox
    900
    Yep, your right. and if there is corrosion in the switch causing a ground the engine will not start. Therefor the suggestion to check that area. Trying to be thorough and help out. Seems like you have it well under control.
    Have '85 350X-XR500 Hybrid,
    Had Nicholson framed: 90/110, 185s, Gen I 500, Gen II 500
    Had Bandito Framed 90
    Have Vey's Framed 90
    Have too many parts
    NE Indiana
    1,067
    Yes, I took your advice when you explained that before and unhooked the kill switch, and the kill switch is currently not hooked up at all. So, I guess that isn't this particular problem.
    NE Indiana
    1,067
    Quote Originally Posted by beets442 View Post
    Thanks for the bout of confidence, bro.
    Yeah, I agree, I'm thinking CDI at this point since it seems to be erratic working at one point then not at other times. I don't know. I'm just so electrically ignorant, no joke.
    Apr 2008
    NW, IND.
    842
    Hoosier I sent you a PM-Beets
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    NE Indiana
    1,067
    OK, I got it. Sent back.
    Beets, I liked that picture you posted and then took right down. I wonder if I was the only person to see that?
    Apr 2008
    NW, IND.
    842
    I didn't want to get in trouble so I removed it.
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    ATCST@Verizon.net would love to see it
    NE Indiana
    1,067
    What did I miss?
    Dec 2009
    Syracuse, Utah
    350x spark problems
    I have a similar problem with my 350x. I just rebuild the motor. It has great compression. Its getting fuel there just seems to be intermittent spark. I replaced the coil and plug and now it has spark but still won't start. I have tried pull starting it with a four wheeler and it will only fire if i turn the kill swith off and then flip it back on it will fire once. If i'm pull starting and flipping the kill switch back and forth it will keep popping but stops when i stop. My next step would be to either replace the stator or cdi box. Does anyone know how to test the cdi box? Sorry to jack your post it wouldn't let me start my own.
    Feb 2009
    michigan
    2,387
    Quote Originally Posted by KiLLaD View Post
    start a new thread.welcome to 3ww.
    1985 ATC 250R
    . Team Red Trike
