Thread: 83 250r PROBLEMS
    Aug 2009
    indiana
    31
    83 250r PROBLEMS
    I cant get the bolt out the swing arm.... iv tried alot but figured somebody has found an easier way to this maddness..... if somebody could let me know the best way to unseiz my swing arm... id appreciate it.... thanks
    ForeverThreeWhe's Avatar
    ForeverThreeWhe is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2009
    Australia
    356
    If you look at what i said in my reply bro you'll realise that this is a common problem
    http://www.3wheelerworldforums.com/s...d.php?t=101599
    Unfortunetly theres no easy way out. I think that the swingarm bolt removal is a "By Any Means Possible" situation. My Dad does the majority of the work on my trike and he couldnt believe how rediculously seized my bolt was. 2 days of rotating, soaking and extreme beating before mine gave way.
    Toronto Canada
    697
    It can be a major hassle to say the least... I had to sawzall mine out - luckily I had another swingarm/pivot bolt to use for my rebuild... otherwise I would have had to use a press to get the sized bolt parts out of the swingarm :/
    Jun 2009
    Tunkhannock,Pa
    904
    thats funny cause i had no issues with my swingarm bolt what so ever
    1985 200X
    66mm H&S Piston
    Little Bit Bigger Cam
    Bassani Exhaust
    1985 350X With Bassani Exhaust
    1983 Honda 200E (PARTING OUT!!!!)
    1985 Yamaha Tri-Zinger
    My Feedback Threadhttp://http://www.3wheelerworld.com/showthread.php?105185-Feedback-for-RodKnockRacing&highlight=RodKnockRacing
    Toronto Canada
    697
    Quote Originally Posted by RodKnockRacing View Post
    You are very lucky then - most people ignore maintenance on their bolts and leave them in there rusting away for decades at a time!
    Now that I have a fresh rebuild, I plan on removing and lubing that sucker yearly! I also heard from someone on these forums a great tip - tap a lube nipple onto the swingarm so that you can keep it nice and greasy without needing to remove it!
