I pulled the rocker cover of my 200x because there was a lot of sealer around it. I don't have the motor off the bike, I just lifted it up like 2 inches and removed the old and fixed it. I also loosened the CDI cover don't know if that matters
When I set it back down, it doesn't sit flush no matter how I position it. Both pins are there along with the oil plug. I tighten it down according to the manual its like 20foot pounds or something like that. It sat flush after that.
My kicker is shot, So I cant use that to turn it over, before I was able to turn it over with a big wrench on the rear hubs, I cannot do that now. But If I loosen the cover I can? But I can rotate the flywheel with a socket just fine.
Is this normal? Did I miss a step?
