I need help. I put on a new ricky stator and flywheel combo. Everything is wired correctly and I have great spark. Now when I kick it over, I am getting fuel dripping out of the front of the jug, so I figure it is a carb problem. Took apart the carb and cleaned thoroughly, float valve appears to be working, the bowl is totally full when I took it apart, put it back on and still sending fuel through the front of the jug where the pipe meets up. Is my float valve bad? could it be anything else that i am not thinking of? Any help appreciated.
Ride free,Brotha. See you in Heaven.
