Results 1 to 3 of 3
Thread: can any carb be used with alcohol?
    Apr 2008
    Kalamazoo, Michigan
    814
    Can you take a regular 39 pwk and use it for alcohol? Is there any neccessary procedures to do this?
    What about a lectron carb?
    Mar 2008
    Tug Hill
    1,282
    methanol or ethanol? regular gas has a fuel/air ratio 1:12 methanol is 1:4.5 ethanol is 1:6.5 so you have to jet way up. if your using methanol multiply your stock main by 2.6. it might be a little rich but a good starting point. lectron carbs are the best for this application. alcohol fuels like to corrode carb parts so some people run a few ounces of gas through after each race/ride.
    Jun 2009
    OHIO
    103
    You would have to drill out the dump tubes as well as jet way up. Its best to just buy an alcohol carb designed for the application. It can be done though, Jetting it to run good would be a challenge. I have an alky carb~41.5~ set up for sale if your interested.
