Results 1 to 10 of 10
Thread: 85' 250R Kicker Spring Broke?
    NewfieBish's Avatar
    NewfieBish is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2008
    Cupids, Newfoundland
    267
    Hey all, my buddy took my 250R for a run today and about half an hour later he came down my yard pushing the bike.. he said the plug fouled (which it did, nothing suprising) and he had spent a nice while trying to get it started, in any case, now the kick starter goes down, and wont come back up, the spring is broke I think. Just looking for advice, I wanna keep riding the bike until I can get enough parts together to make it worth tearing into it to rebuild, is it ok to drive the bike with the kicker bungee corded to the frame in the proper position? And if anyone knows off hand, how hard is it to replace the spring?
    Thanks Again!
    85' ATC250R
    bigred44's Avatar
    bigred44 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    Ithaca Ny
    361
    I've had the kicker on my XR500 bungeed for a couple months now. Just make sure you have it on there good and functional to keep the kicker up where it needs to be or it will kick back on you. As far as replacing the spring i dont think it is too hard, just have to take the clutch cover off and everything is right there.
    '84 ATC 110
    '84 200x
    '85 350x
    '86 125m
    '03 Shadow ACE 750
    '05 Brute Force 650
    NewfieBish's Avatar
    Sep 2008
    267
    thanks man, i guess i can go a couple of months for sure then :P
    85' ATC250R
    Aug 2009
    WI
    32
    i wouldn't go a couple of months. The spring is probably like 20 bucks and its only like a 15 min job.
    Every breakdown is different and you could have a piece of spring floating around in your case, which could REALLY ruin your week
    Thats a spring even I have kicking around and the only other thing you need is a gasket, lay it on the side and you don't even need oil.
    I'd pull it apart and ask in classifieds if someone will send you one. I have the whole gear set from a crate motor so I don't want to give up the return spring. But, if I have an old one your welcome to it. I'm sure someone has a couple kicking around
    I tell guys that if something doesn't start in a few kicks, pop start it or get it jetted right, replace the plug etc etc etc.... But kicking and kicking just beats the crap out of our old and rare parts.
    EDIT - Replacing the spring is chicken, but honestly - 50% of people who remove kicker guts cannot get them set back correctly. It's easy, half the job is merely lining up dots on gears and the shaft but there is a trick to getting the return spring loaded properly.
    I have to get a camcorder cable and take a video of how it's done because allot of guys have issues with it.
    NewfieBish's Avatar
    Sep 2008
    267
    thanks DC, i was thinking the same way about the whole peice of metal floating around in the motor haha, id say ill get a spring and do it up.. would a spring from one of the early TRX250R's or CR250R's work? just wondering, it'd be nice to buy a new one
    85' ATC250R
    NewfieBish's Avatar
    Sep 2008
    267
    Question Will a 86' TRX250R kicker spring fit my ATC 250R?
    Just wondering because i got one ordered.. will a kicker spring for an 86 TRX250R fit a 86 ATC250R motor?
    85' ATC250R
    Why did you order a TRX spring (I do believe it will fit though). Is the ATC spring gonezo?
    Like I said, we probably have a couple hundred of them between all the guys, you would just have to post in classifieds.
    NewfieBish's Avatar
    Sep 2008
    267
    i never even bothered askin for the ATC spring, weird hey? haha, but yeah they are interchangeable, the part numbers are the same. I shoulda asked about the trike spring, that's it i guess, its $12 taxes in, nuttin to it.
    85' ATC250R
    Masshole
    2,191
    Flip that pig on its side, take the pipe off. You can take the r-s clutch cover off without taking the rad hoses off, providing they havent already been trimmed back. By flipping it on its side, you wont lose any oil either. Buy the gasket if your ordering the spring in case the old one tears. Dab oil on one side of the new gasket before you put it back together. This will allow you to re-use the gasket later on down the road, it wont stick to both sides and tear.
