350X Frame gussets and welding - another one for your pleasure!!
I have another 86 350X frame here to do for a 3WW member thats local. He can reply if he wants to be known....
I guess the shipping scares guys away but according to GOAT it may be possible to ship them cheaper than some people assume. It does take a good 6-8 hours to fab the gussets, remove the paint and mig weld them back in place. It all went very well though......
I have some other pics to add but can't find my KODAK camera manual and I need to swap them from internal memory to the memory card which of course is impossible to do by the menu
I'll post them up when I figure it out
Sadly, even the 86 frames with the updated wrap crack so it had to go - BYE BYE!!
I added another gusset this time to the lower frame rail, I've never seen them break there but it looked lonely and seemed to want some friends
Only took a bit more time so what the heck.
Here's some pics:
You can see here how I get that frame wrap to tie into both the upper and lower gussets I fabricate, IMHO that should make it SUPER STRONG!!
Never, EVER use that stock frame wrap (yes, even 86 model) and motor mount without beefing it up
The shock pushes UP and the frame and your weight push down. The one single mount on the left side takes allot of abuse. BEEF IT UP!!
I may even weld another small boss or two to that motor mount that absorbs all the stress before I finish. Thank god I have a spare naked motor to line everything up.......
Roy AKA "TANKS350X" said "Hey, don't make it better than mine"
but it's all a learning experience and you learn from each one and apply that to each new build
It should be done soon, I still have to finish the motor mount and the rear seat pin area that cracks. Some people talk about the neck twisting, I haven't seen it or done it myself yet (DC knocks on wood) If you roll it that hard I may as well make the whole frame out of .250 tube and plate
Reason: More to say AGAIN
