Thread: 1984 honda 200s issue
    keene nh usa
    3
    hi everyone i am hoping someone can help me with my atc issue. on my 1984 Honda 200s if your driving along and let off the throttle it still wants to go even after you let off, it's not doing it aggressively but it's still wanting to go. i am not sure what could be causing it as i know only a little about Atvs/ATCs. in a possibly unrelated issue it also does not like to sit and idle it will stall if you don't hit the gas every 30 seconds or so. any help would be appreciated.
    Feb 2009
    Wisconsin
    521
    Take the carb off and clean it with some carb cleaner, pull the slide off and the bowl and clean the jets real good.
    1985 Auto X lots of upgrades
    1982 Honda 185s 3inch wheel spacers, bassani exhaust
    2001 400ex
    1983 110
    6,811
    This is usually caused by a worn carb slide or a partially clogged idle jet . Once you clean the idle jet it will probably be idling high and will have to adjust the idle screw down a bit .
    keene nh usa
    3
    Thanks
    thanks for the information guys learning a bit every time i play with this stuff. hopefully i will get a chance soon to tinker with it. If this Carb slider thing is damaged can you order a replacement or do you have to get a new carb?
    Mar 2007
    Texas
    5,045
    i have a spare or 2 if you need one you can have it. just pay for shipping.
    ________________
    https://www.mikesatvfix.com
