Thread: Nuetral switch question
    Houston
    77
    I have a 250sx I can't get the nuetral light to come on I'm assuming it's the switch that tells it it's in nuetral that is bad when I jumped the solinoid (sp) it fired up. Is there an easy way to ground out this switch if do where is it and wires am I looking for and what should I do with them.
    I also have a question on the brakes they aren't very strong and won't spring back to position any easy solution or should I tear them down and clean and replace parts.
    Thanks j.b.
    Pa.'s Highest City
    8,058
    your wires and connectors are down alongside the one footpeg(left side) I believe. back behind a little guard or cover. unhook them and clean with some wd40 or a small wire brush.
    also make sure they're connected back behind the dash on the handlebars. good luck!
    Yep, clean and replace worn parts on your brakes. Make sure you properly lube or replace the cables. They aren't going to fix themselves.
    Houston
    77
    I've got a new switch I just can't find the old one
    Houston
    77
    Sweet found it it was buried under gunk
    Cleaned it up it works now the light bulb is bad but my e start button works now
    I just need to get the brakes working the bottom of the carb leaks and I have to figure out something for a gas tank
