Results 1 to 15 of 16
Thread: What Kind Of 110 Is This???
    big schott's Avatar
    big schott is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2007
    Western Minnesota
    244
    I bought this POS for $100. I just need parts and I have no intention to fix er up.
    The guy said that he couldn't get it running and after taking it apart I think I know why...
    [IMG][/IMG]
    OK it is a 1983 frame but I think a 1979 motor was put in at some time...
    [IMG][/IMG]
    and I think they tried to use the CDI on this older styl motor...
    So... here are the questions...
    Can this motor run with CDI or do I need to find the points set up for it?
    If I need to change it to points do I need to get a differant head for it??
    and Is this a good canidate to modify? (high comp. piston, cam, intake, carb, exhaust.. )
    1978 Honda 90 / 1979 Honda 110 / 1983 Honda 110 Racer (in the Works)
    1973 Honda 70 / 1983 Honda 70 / 1983 Honda X-mas special / 1984 Honda 70 / 1985 Honda 70
    1985 Honda 200X Stock Original
    1985 Honda 350X
    1985 Honda 250R
    1986 Honda 350X
    1987 Honda 250SX
    Houston
    77
    Why do u want to change it over to points
    Nice ninja 250
    Houston
    77
    I don't think the cdi stuff will fit in the points cavity I'm almost positive that the cdi cover will not fit on the old style motor
    Don't qoute me I'm not 100% sure
    6,811
    79 110 bottom end with that fly wheel is for points so the cdi will have to go . The cam is also longer so your going to need the cam for a points motor and chang it back . the harness is also probably different as is the coil if its for the 83 . Probably easier to buy a good 81-83 bottom end and just change that and make it CDI.
    big schott's Avatar
    Feb 2007
    Western Minnesota
    244
    The wifes bike (250 too small for me I like my CBR 1000).
    I am getting no spark, and I have heard that it is hard to mod. a 110 with CDI.
    I have checked all parts with exchanging them with my other 110.
    [IMG][/IMG]
    Spark plug coil.... Good
    CDI ... Good
    I didn't take out the CDI pick up though..
    1985 Honda 350X
    1985 Honda 250R
    1986 Honda 350X
    1987 Honda 250SX
    big schott's Avatar
    Feb 2007
    Western Minnesota
    244
    Close.. I have no problem making my own harness to make this motor run.. I have already found a points set up. I need a cam so what is a good performace cam for this 110 to make it a beast ? I will also need a differant spark coil if I'm not mistaking.
    Also Shortline.. I'm glad you chimed in on this one.. I have checked out your project and LOVE IT!! I'm already have the Nicholson frame for it and am having it sand blasted as we type...
    This is what I have in mind..
    [IMG][/IMG]
    1985 Honda 350X
    1985 Honda 250R
    1986 Honda 350X
    1987 Honda 250SX
    6,811
    Quote Originally Posted by big schott View Post
    [IMG][/IMG]
    CDI ... Good
    WHy is it so hard to mod a CDI motor ? Here is mine PK big bore , HP cam , 24mm mikuni EXC
    6,811
    Are you sure its a nicholson ?? Looks like a johnson bandito frame to me .
    big schott's Avatar
    Feb 2007
    Western Minnesota
    244
    Shortline10,, I have read here somewhere that the CDI is not what you want but, that is the machine that moved me to try this...
    So with that being said.. What should I do with this motor? It has great compression, the coil is good and I think it will make motor to modify.
    1985 Honda 350X
    1985 Honda 250R
    1986 Honda 350X
    1987 Honda 250SX
    big schott's Avatar
    Feb 2007
    Western Minnesota
    244
    90% sure. It will work good , it's straight, and I got it or under $50.
    I think it will work. ( I'll get better pics after the sand blasting)
    1985 Honda 350X
    1985 Honda 250R
    1986 Honda 350X
    1987 Honda 250SX
    6,811
    you can use the high performance cam from a points motor on a CDI motor only difference is you will have to add a spacer to make up the difference for the length of the cdi which stick out about a 1/4" more . CDI cams are not common and in the aftermarket world . I know web will make you one but it expensive . Yorr top end wont work with your bottom end because that bottom end cant be converted to cdi , Fly wheel different wont bolt up . fly wheel electronics wont bolt into that bottom end either . also pull starters are different . Going to have to figure out which way you want to go and buy the correct parts .
    6,811
    Frame
    Frame is fine and will work with an 83 110 set up .
    big schott's Avatar
    Feb 2007
    Western Minnesota
    244
    I am planning on ditching the CDI stuff. I think putting this motor back to points is the way to go.. I read that the 90cc cam will work fine and they are cheap even for the performance ones. Do you know if this is true?
    1985 Honda 350X
    1985 Honda 250R
    1986 Honda 350X
    1987 Honda 250SX
    6,811
    cams
    ATC90 HP cams bolt in fine
    Trailpro
