Results 1 to 9 of 9
Thread: Tips for painting gas tank?
    Santa Barbara, California
    1,161
    It's time for me to start making the 200x look a little better so first things first I need to repaint the gas tank! It is pretty dent free but has some green overspray on it from the old owner and old stickers on it, etc.
    So what should I do to prep it for paint? Just sandpaper it (what grit is best for this application) and any sort of special paint I should use?
    Thanks again!
    1985 Honda 200x
    Southern MN
    1,875
    I would start at probly a wet sand paper 220 work your way up to a 600 or so. maybe use a razor blade to take the stickers off, prime it, and sand the primer with like 600 or 1000 grit. I would'nt use rustoleum paint, and the gas will eat at it if you spill a little on the tank, and make it turn brown. I would go with some engine paint or such from an automotive store (napa, advanced auto, parts city, etc) That paint seems to hold up a lot better. If it were me, I would rather paint it with a pneumatic air gun, but not everyone has the setup. Remember, prep is the key to make the final result look the way you want it.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Feb 2009
    Rome,NY
    1,046
    I allways wondered what that pearl white Cadillac paint would look like on a wheeler ...
    6,802
    If you want to use knocker ball paint I would recommend a lacquer as it is less prone to have issues with gas . Can buy it at your local auto repair store .
    The tough thing about tanks is that if you spraybomb it, you'll have to be very careful with overspill for awhile. IDK why? but it seems like once the paint is on for awhile, sits in the sun, gets washed etc etc - it gets a bit more tolerant to fuel spills. But Edog paint has it's limitations esp in a petroleum environment....
    Grind or blast off any rust, fill the holes with puddy and big dents with Bondo (bondo likes a rough surface, like 60 grit) then scuff it all up with some 400 grit or so and have a ball. Sometimes when I have used reg paint, I do one coat, then wet sand that with 600 and do a couple more coats.
    We all know it's not gonna be an outstanding finish so look at it like an expirement and do the best you can. It's big money to coat and restore a tank and probably the main reason that guys switch over to plastic. Butr, for a few hours and 20$ worth of paint and materials it's worth a go
    Good luck and POST UP PICS
    Oct 2008
    NB, Canada
    852
    I used Krylon paint on my 200m tank, and if I got any gas on it, the paint would ripple where the gas was.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
    "Wear Limits Are Just A Suggestion"
    s. louisiana
    38
    I have had success using spray can appliance epoxy from Home Depot. The white lays good and it has held up to gas spills.
    Dec 2002
    deer park, texas
    2,336
    If you have a gun, just spray it with some good automotive paint. For little jobs like that you can buy a premixed bottle. You can spray a tank and have a bit left over. I buy mine from house of color. $8 for a premixed bottle. Just put in gun and spray ( maybe thin a bit ). Also for small jobs like that you can buy cheap HVLP guns off ebay that work great.
    On a tank i basically follow this.
    If tank is dented, strip the paint off the top of the tank. Apply some putty. Sand it down smooth starting course and finishing with 220 or 400. Apply a thick layer of primer. wet sand it down with fine sand paper 600 or better. Might need to apply a second coat of primer depending on skills and repeat. Apply your first coat of paint and wet sand with very fine grit. Apply as many coats as you want. Spray with clear. If you want extra coats of clear which i prefer. Wetsand, apply etc etc until your happy. It is pretty simple but expect to screw up your first few times. My first time to paint a car was a nightmare.
    Never argue with an idiot. They will bring you down to their level and beat you with experience.
    Calling an illegal alien an undocumented immigrant is the same as calling a drug dealer an unlicensed pharmacist.
    1981 Wife ( Project)
    Sep 2008
    845 New York
    2,302
    Quote Originally Posted by AutoXer View Post
    that would look crazy... caddy themed trike anyone????
    1985 Quad Killer
    1985 Mini Raag
    1985 Green Gobbin X2!!
    1990 Kawasaki 300sx
    R.I.P
