My buddy and i were riding the other day and after a few miles i noticed my 125m kinda bogging down. We stopped to take a break and we noticed quite a large amount of oil coming from the crankcase breather tube. We turned around and headed back to the truck, but not long after it started to die. I was unable to get it to crank start, it would only start by pullstarting it. After a short while it wouldn't start at all...... i stopped to check the oil level frequently and the level seemed fine. We also noticed one of the tubes on the carb had come loose...but it seemed to run worse when i re-attached it. I noticed very little oil in the breather box, and the air filter was clean. Any ideas on what might be going on?
This weekend i plan to clean the carb, drain and replace all the oil, and put in a new plug and see what happens.....any help would be appreciated!
