Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Thread: Help! Lost Power!
    bonkers_200s's Avatar
    bonkers_200s is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Middletown, NY
    393
    I've been told synthetics would cause some slippage, so I've never ran it.
    You can get the manual in pdf format from a link in one of the threads kicking around here somewhere, and that also says 10w 40.
    I'd just stick running whats recommended by Honda
    If you can't fix it with a , its an electrical problem.
    85 ATC 200s--Ratted out and not running at the moment
    86 ATC 200x--All stock other than the handle bars
    85 ATC 250es Big Red -- Just got new rubbers and she wants to ride!!
    04 Suzuki LTZ250 quadsport - It was a decent price and I'm a raging idiot.
    Houston
    77
    20-w50 a common motorcycle oil will work that motor at that milage shouldn't need a thinner oil because of tight tolerences
    If it had tight tolorences it probably Dosent any more do to high usage
    Aug 2009
    Newfoundland, Canada
    915
    well if I was to put in new rings and valve stem seals etc, would I still need a thicker oil or would I just stick with basic 10W40?
