Results 1 to 15 of 15
Thread: I'm finally one of those guys I hate
    bonkers_200s's Avatar
    bonkers_200s is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Middletown, NY
    393
    Last night I bought an 85 250es bigred for SIXTY FRICKEN DOLLARS!!!!!!
    I was visiting with my mother, like a good little boy. I get a random phone call from this guy. Last year I offered him $400 for it and the deal just never went down.
    Now he says $50 and faster than greased owl @!$#% I kissed momma goodbye and floored it to his house, loaded it in his truck and had it dropped at my house before he could change his mind, gave him $10 for gas.
    All stock, all original, I believe I'm now the third owner.
    Needs all new rubbers and isnt running.
    The carb was so damn clogged up I almost didn't believe it. I got it all pretty and back together again. Now the over flow continues to have fuel flow out of it.
    Thats how far I got at 4am and couldn't see straight any more so I gave up after have the carb on and off twice.
    The float doesn't seem to be stuck unless its rubbing on the inside of the bowl and I can't see it.
    Any suggestions?
    Also, does anyone know how much fluid should be in the back end drive differential?
    Everything that I can see throught he fill plug looks great, its wet but doesn't seem to have very much fluid in it.
    If you can't fix it with a , its an electrical problem.
    85 ATC 200s--Ratted out and not running at the moment
    86 ATC 200x--All stock other than the handle bars
    85 ATC 250es Big Red -- Just got new rubbers and she wants to ride!!
    04 Suzuki LTZ250 quadsport - It was a decent price and I'm a raging idiot.
    Sep 2007
    100mi west of Chicago
    3,582
    Good pick up! I have had good luck adjusting the float to stop the flow of gas. I just bend the tab a little so that the stopper goes up in the passage far enough. This has worked on 2 carbs for me.
    Rob
    Middletown, NY
    393
    Thats a good trick to use, but this isn't a brass float. its all plastic except for the needle valve and I'm scared to snap it.
    I'm thinking maybe over time the rubber tip on the needle valve may have shrunk? I like the old brass ones much better.
    Eastern Long Island
    1,688
    The final drive holds a little over 3 ounces of 80w gear oil. The 1985 models had a problem with water getting in the rear from a bad seal on the swingarm boot so keep an eye on that. There is a drain plug on the left side of the drive or you can remove the fill and stand the bike up to drain it.
    Lots O Trikes!!!!!
    May 2009
    Brampton, ontario
    686
    the float may not be getting stuck. but if its as dirty as you say.. the pin holding the floats on if it gets to dirty or corroded can jam the floats. kept happening to me. i pulled it out cleaned it off nice and now im good.
    Looking for some smaller style tires like the r's have, just 2 back tires. pm please.
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Quote Originally Posted by bonkers_200s View Post
    Any suggestions?
    Middletown, NY
    393
    Sorry the camera in my phone is on the fritz, and I had a choice, run out and waste money on a new trike to play with or go buy a camera.
    I chose new trike
    Oct 2008
    NB, Canada
    852
    The way I test all float type carborators is that I take them off, emty the bowl of gas, flip them upside down, and try to blow into the spot that the fuel line hooks onto. If you can blow through easily, the float is stuck up (up, now that the carb is upside down).
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
    "Wear Limits Are Just A Suggestion"
    Middletown, NY
    393
    Quote Originally Posted by Gearheadtom View Post
    Did that and I still taste gas all damn day. works like a charm as long as you don't put it together.
    Another thing I'm mulling over in my head, the bottom screw to open the drain when I took it out to clean the bowl was cranked in very tight and had some shmootz around it.
    I'm wondering if thats not seating properly or if the o ring on the pin is damaged now and allowing fuel to pass through.
    But, I'm stuck at work until midnight and am forced to work on pin spotters instead of trikes All these thoughts running through my head are useless right now
    Apr 2006
    Crestview, Florida
    2,429
    sounds like it time for a carb kit.
    Rides
    85 ATC350X
    85 ATC200X
    howard, ohio`
    52
    I agree with erics350x and soak the carb overnight in carb cleaner wouldnt hurt either but beware carb cleaner will ruin seals so remove them. (aka it warps seals)
    86-87
    http://cgi.ebay.com/HONDA-86-87-ATC-...d=p3286.c0.m14
    85
    http://cgi.ebay.com/HONDA-1985-ATC25...d=p3286.c0.m14
    I'll answer your dumb questions, if you answer mine...
    Sep 2007
    3,582
    What I like to do is take the carb off and test it with water in the sink until I get it to stop leaking. That way you aren't wasting gas and stinking up your garage in the process.
    Rob
    Middletown, NY
    393
    Update
    It sat in pieces long enough to fix itself as far as the gas leaking goes.
    Got it running last night, this thing is a one kick monster.
    Rear brake was froze, got that working and what not.
    Reverse cable is broken.
    Heres where it gets real !#$#$% stupid.
    Its a friends house that I've rode with and worked on junk with my whole life. Hes over eager and likes to take on a lot of stuff because he thinks the rest of the world can't do them.
    The electric start doesn't work when he hooked it up to a jump box. There was a wire that I repeatedly told him is ground wire. It has an eyelette and was placed on the same bolt that holds the airbox to the frame. Turn my back and the SOB puts juice to it and poof we've got smoke coming from just about everyhere that theres a wire plugged into another one.
    Thank god it still runs that green wire runs into the stator and is now slightlyt charged here and there.
    Should I kill him?
    Mar 2007
    Texas
    5,045
    kick him in the nuts with pointy boots!!! I would.
    ________________
    https://www.mikesatvfix.com
    Sep 2008
    845 New York
    2,302
    ^^ take him for a ride really far away and he will be ate by a bear.....
    1985 Quad Killer
    1985 Mini Raag
    1985 Green Gobbin X2!!
    1990 Kawasaki 300sx
    R.I.P
