You can swap all the parts between the 2 years,except for the 86 coolant bottle wont fit the 85 frame.
The 85 trees and forks will fit the 86 frame, and vice versa.
The rake was changed in the trees.
The 85 was raked out more and the 86 trees were raked back.
The 85's had a tendency to push, in the corners and felt twitchy at high speeds.
So they raked the forks and tripples back in 86 and beefed up the fork tubes to help that twitching/pushing feeling out, and inprove the front suspension action..
The trottles were different in 86 too.
You have to use the 86 throttle cable with the 86 thumb throttle.
Proudly NOT a member of
"Team on the Teat"
