Thread: Engine Painting > Help!
    Aug 2009
    Newfoundland, Canada
    915
    do you guys think that putting high heat enamel on an engine would last. Because I tried it with a few components on my engine, like the valve covers and that. If I were to do the engine, I would put a high heat primer, high heat enamel and then finally a high heat clear coat. would this work, or just all flake off?
    Apr 2008
    NW, IND.
    842
    Yes, I would glass bead the surface lightly to be painted. Prime and glossy paint, no clear...Beets
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    Aug 2009
    915
    ok, what about a light sand paper?
    Apr 2008
    NW, IND.
    842
    Yea, if you can get those tight area's without breaking fins? Take your time and do it right. Thin coats and lots of dry time. Let us know how it goes. Beets
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    Aug 2009
    915
    alright, thanks . I can get to those places no problem. I will do the rocker box cover first and see how it turns out and see if I want to do the whole thing.
