Results 1 to 12 of 12
Thread: Installing a manual clutch on an atc90
    bandito90's Avatar
    bandito90 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Pa
    284
    Hey,Just want to see who has the specifics on converting an atc 90 to manual clutch.Or rather what needs to be changed internally to install it.I already know it will need cover and all the clutch internals.But is the crank the same?Also what are the differences in the gear ratios of other honda 90 motors that were put into bikes?
    1978 bandito framed atc90
    1984 YT60
    1974 rd60
    2002 Buell Blast
    1984 Honda xr100 project in the trunk of my car.
    1964 honda C100
    1981 Honda Hobbit
    1984 Yamahopper
    6,811
    Hey bandito I just did one of these on the last thread I started . The atc90 shifter shaft is different also so you will have to shorten the length of the atc90 one so it will fit the manual clutch cover . Yes the crank is the same on the clutch side for sure and bolts right on .
    Apr 2006
    PA
    1,464
    I think it would be easier to just get a cheap lifan manual and bolt it in there.
    bandito90's Avatar
    Pa
    284
    Thanks guys.Shortline I saw your thread.So I just need to modify the shifter shaft?
    1984 YT60
    1974 rd60
    2002 Buell Blast
    1964 honda C100
    1981 Honda Hobbit
    1984 Yamahopper
    Lancaster, PA
    1,738
    Lifan is not a "bolt up" for an ATC90, it can be made to fit but it is based on the Z50/ATC70 motor which is not the same as a ATC90
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    6,811
    sl90
    Quote Originally Posted by blue27 View Post
    The parts I have found to work the best for me are the 1969 honda SL90 manual clutch set up . With a little mechanical ability its not that hard and bolts right up to the atc90/110
    Sep 2003
    Elizabethtown PA
    1,581
    hey Timmy we just have to bring my engine down from the atc90 i got at the truck show. we could rip it apart to see what needs switched. it has a manual clutch stuff like Shortline's.
    i almost got my Bandito frame atc 90/110 together.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    bandito90's Avatar
    Pa
    284
    Jason that would be cool.If it's just a parts swap with a little modification here and there it should be easy.Anybody know if there are heavier springs for these?
    1984 YT60
    1974 rd60
    2002 Buell Blast
    1964 honda C100
    1981 Honda Hobbit
    1984 Yamahopper
    6,811
    Quote Originally Posted by bandito90 View Post
    I used the Versha HD clutch spring kit from the auto atc90 on my manual set up . Their about a 1/4 inch longer and much stronger .
    When we have guys like Vealmonkey, Blue, Shortline and Banditio - LIFAN is NOT the easy or correct solution
    Thank god for you old school guys
    bandito90's Avatar
    Pa
    284
    I'm trying to keep it period correct as much as possible.The after market parts are more plentiful for the z50 based motors,But I've always liked the 90/110's
    1984 YT60
    1974 rd60
    2002 Buell Blast
    1964 honda C100
    1981 Honda Hobbit
    1984 Yamahopper
    Lancaster, PA
    1,738
    I don't know if I am old school...or just to old and stupid to understand new school,lol
    thanks Dirtcrasher
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    and many more!!!
    Blue Line Graphics
