Results 1 to 7 of 7
Thread: 200x head problem
    atcrider1's Avatar
    atcrider1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2009
    Montrose MI
    400
    200x head problem
    just did the top end of me x, it rolls over fine but when i put the timing gear cover behind the cdi it locks it up
    why does it do this?
    " I gotz the 8-track player mounted to my Oly, it's pretty sweet for trail side dance parties....."
    -Uller God
    Are the cam sprocket bolts hitting??
    Is the cam shaft binding in that cover??
    I think your just overlooking something simple.........
    Any pics?? we'll figure it out
    litebulblsc's Avatar
    litebulblsc is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2009
    LaSalle, MI
    313
    You need to put a gasket behind it. Went through the same thing the other day
    And a red 2000 silverado
    atcrider1's Avatar
    Mar 2009
    Montrose MI
    400
    thats why, the gasket fell apart so i put silicone on it
    -Uller God
    Anytime you guys have a binding issue, start by backing the bolts off - that may tell you everything.
    The other thing I use is "machinists ink or Dykem" It shows whats rubbing on what and tells a story. Sometimes even a fat Black Sharpie marker shows you whats rubbing on what.
    And LAST, are the dowel pins. If you ever take crap apart and forget one or both (there are usually 2) dowel pins, you will have some type of alignment and or binding issue........
    May 2009
    LaSalle, MI
    313
    Ya, I did the same with silicon. Buy a gasket or some gasket material and it should be good. It has on an o-ring so the gasket is just for a spacer. It is the pulse generator base plate. The gasket cost a couple dollars from a Honda dealer, or you can get the roll of gasket material for $5 form an auto parts store and cut your own out
    atcrider1's Avatar
    Mar 2009
    Montrose MI
    400
    problem solved, i cut a gasket out of a cereal box for now until i can get the real thing
    thanks alot guys
    cody
    -Uller God
