Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 43
Thread: Will 86-87 TRX 250R motor also fit 85-86 ATC250R ?
    ct
    1,396
    just wondering ? guy needs 2 motors and there are some available but they are from TRX's. Will they fit right in our 250R's ?
    Mar 2008
    Tug Hill
    1,282
    not positive but im pretty sure they are identical
    Masshole
    2,191
    85-89 all interchange. trx and atc
    ^X2 - All the same beside colors, differences in cylinders and the longer rod in the 87 and up TRX motor........
    Oct 2007
    Grosse Tete, LA
    3,440
    which one runs harder? long rod or short rod? stock for stock all other things equal
    Mar 2008
    Tug Hill
    1,282
    short stroke revs faster
    Oct 2007
    Grosse Tete, LA
    3,440
    but long rod has more torque?
    Mar 2008
    Tug Hill
    1,282
    thats the general belief. the more square the boreXstroke the quicker reving the engine is. and a long rod engine has more torque
    ct
    1,396
    thanks for all the sweet info guys!
    Apr 2008
    Kalamazoo, Michigan
    814
    85-86 does not have a bridged intake, therefore can create more power by less resistance.
    As opposed to a 87-89 motor
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,242
    Quote Originally Posted by lndy650 View Post
    THE BORE AND STROKE IS EXACTLY THE SAME ON ALL OF THE MOTORS!!!!
    SO YOU CAN THROW THAT THEORY OUT.....
    Mar 2008
    Tug Hill
    1,282
    the bridged exhaust port allows the port to be much wider witout being a ring snagger therefor making much more power than the older style
    the stroke is most certianly longer KASEY
    KASEY's Avatar
    4,242
    Quote Originally Posted by MagicJames View Post
    THE RINGS ARE THE ONLY PART THAT REALLY CAUSE RESISTANCE, THE PORT TIMING WOULD BE THE ONLY PART THAT WOULD CREATE MORE POWER,
    KASEY's Avatar
    4,242
    the stroke is most certianly longer on the newr engine KASEY
    DUDE ,,its not!!! all atc and trx motors have a 72 x 68 mm bore and stroke,,, and if you have had both cylinders side by side you would see that the top part of the intake port is the same ,, so the ring snagger theory is out the window too!!!
    Mar 2008
    Tug Hill
    1,282
    you have no clue what your talking about do you? a wider exhaust port will always result in more power. and what are you talking about the intake port for?that is irrelevant to this subject
    port timing changes what rpm you make power at. why dont you do yourself a favor and buy the 2 stroke tuners handbook and read a bit
