Results 1 to 15 of 25
Thread: Some 86R questions and pics
    Dec 2006
    St. John's Newfoundland
    1,587
    Was out yesterday picking doing a little clean up on the bike. Was half afraid to hit it with the pressure washer until I ask here. So anyone use this method and what do you remove?
    The bike has an exhaust leak on pipe leaving the head, so over the phone I said I wanted whatever gasket there was and this is what Honda gave me. I have no idea where it goes and I think the rest has to be replaced aswell. Will high heat gasket silicone work where the flange mounts to the head, that flat gasket that was there is shot?
    Any idea how to adjust this and I dont believe my chain should be able to move that much.
    1986 ATC 250r
    1985 ATC 250r
    1985 X2 ATC 70's
    1985 XL 80
    Dec 2006
    1,587
    Why would someone have the rims mounted inside out?
    1986 ATC 250r
    1985 ATC 250r
    1985 X2 ATC 70's
    1985 XL 80
    Mar 2008
    Tug Hill
    1,282
    valve stems in will protect them and also if the rims are dished it will make the tires out farther
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,248
    THAT LOOKS LIKE 528 OR 530 CHAIN. thats why its so wide on the sprocket, it looks aweful narrow,, so measure the offset on the wheels. if the wide side is to the inside turn them around to make it wider,, if its the same its probably kool to leave the stems in for protection.. as far as pressure washing,,, put the airbox lid on plug the exhaust port good,,, and have at it,,,
    Dec 2006
    1,587
    I know it just fits in my shed door like that, but the rims would make her wider on the right way.
    1986 ATC 250r
    1985 ATC 250r
    1985 X2 ATC 70's
    1985 XL 80
    Dec 2006
    1,587
    Hmmm, I guess a new chain is also in the list of things to pick up aswell. Bought it from a dirtbike and quad guy so I guess he just threw a chain he had kicking around on it.
    1986 ATC 250r
    1985 ATC 250r
    1985 X2 ATC 70's
    1985 XL 80
    Mar 2008
    Tug Hill
    1,282
    probably a motorcycle chain
    Southern MN
    1,875
    Those tires on the rear have a rotation direction arrow, and can only be used one way or they will not hook up properly. Possibly the person who mounted them on the rims didnt notice the arrow until it was too late? Maybe if you turn the rims the right way, they will be on bass ackwards. check it out. Good luck, and looks like a great project/rider so far. --- Jon.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Dec 2006
    1,587
    Thxs folks.
    Ah, yes never thought of the reverse rotation. Guest I will change them around on the rims as well.
    I really need to figure out the exhaust problem. Can I run high temp silicone on the flange where it mounts to the cylinder? And what is the gasket honda gave me?, and that half ring is that suppose to lock into the grove in the flange, I assume yes?
    Here is the part number.
    Thxs
    1986 ATC 250r
    1985 ATC 250r
    1985 X2 ATC 70's
    1985 XL 80
    Las Vegas, NV.
    2,531
    Quote Originally Posted by Brockey View Post
    Thxs folks.
    If you want to put the wheels on properly, so they are wider, and you're worried about the direction of the tires, you don't need to remove the tires from the wheels, just switch the right wheel/tire to the left side, and the left wheel/tire to the right side. That will keep the tires rotating the same direction while the wheels are mounted correctly.
    I've never tried just the silicone & no gasket, so I can't comment on that question, but the new ring does go in the slot on your exhaust flange. Clean out the ring groove good before installing the new ring. After installing the ring, make sure the gap is the top of the flange. That will minimize exhaust spooge leakage. Good luck!
    Dec 2006
    1,587
    Thxs man. I must of had a brain fart about the tires. But I have to keep them that way right now until I move the end of the month to get her in and out of the shed.
    lol
    1986 ATC 250r
    1985 ATC 250r
    1985 X2 ATC 70's
    1985 XL 80
    Masshole
    2,191
    Whats up with your carrier, it looks as if the flange that has the adjustment spanner holes is MIA? Or is it just on the bottom, covered by your hand?
    Mar 2008
    Tug Hill
    1,282
    ^ i was thinking the same thing...
    Dec 2006
    1,587
    I'll get another pic. I dunno it might be missing.
    1986 ATC 250r
    1985 ATC 250r
    1985 X2 ATC 70's
    1985 XL 80
    Dec 2006
    1,587
    How bout these pics of the carrier?. Also threw in a pic of the spare rims and cut tires that came with the bike. The guy told me his grandfather cut them open on him and his cousin for having too much fun with little traction.
    1986 ATC 250r
    1985 ATC 250r
    1985 X2 ATC 70's
    1985 XL 80
