Results 1 to 15 of 17
Thread: 250SX Swingarm Bearings??
    mike84bigred's Avatar
    mike84bigred is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2006
    North Tonawanda, NY
    343
    Got a 85 250sx. Have to do the swingarm bearings soon on it. I pulled the dustcap off it today and was baffled immediatly. My repair manuel says there supposed to be a 17mm allen bolt in there and all I see is a 17mm regular bolt with barelyanything to grab on to. I was starting to round it a bit just putting a little force on it. Is this normal? How do I pul it off?
    84'200s (Dad bought new in 84, long gone)
    84'YTM200 (sold 02)
    85'KLT160 (sold 05)
    84' Big Red (Cobra exhaust,good shape) sold in 08
    84' Big Red (Parts Bike, runs good though)sold in 08
    85' 250SX (New plastic, Clark Plastic Gas Tank, Web Cam Camshaft, Cobra Exhaust, Moose Jet Kit, etc..) sold in 2010 and highly regret!!!
    04 Polaris Sportsman (Swapped 400 motor with a 500, Polaris wheels w/Kendra Bearclaws, Moose Fender Flares, Brushguard, Warn Winch)
    84 200s (Needs work!)
    A pic would be great
    It's usually an internal hex hole and I use a bolt I welded a bar onto......
    Pa.'s Highest City
    8,058
    thats a 15 or 17 mm head on that swinger bolt. I just welded a lugnut to a bolt and turned it out with a rachet. (the correct allen wrench will cost a fortune.) You gotta loosen up that outer nut before you can do that..
    Remove the rear shock,,, Disconnect the rubber boot and slide the drive shaft forward,, and the entire swinger comes off on an angle towards the left side if memory serves me correctly..
    soak everything down with kroil or pb blaster a day or two before hand..
    Oct 2006
    North Tonawanda, NY
    343
    Is this how its suppose to be? Dosen't look like it form what the book is talking about.
    84'YTM200 (sold 02)
    85'KLT160 (sold 05)
    WOW!!
    Have fun getting that one out!!
    Somebody jammed a nut in the center, it should come out with some heat and beating on it. Your gonna need a big punch to drive that outer ring free......
    Soak it and heat it with oxy/acet if possible.
    Oct 2006
    North Tonawanda, NY
    343
    So its not attached to anything? Whats holding it in there?
    84'YTM200 (sold 02)
    85'KLT160 (sold 05)
    Pa.'s Highest City
    8,058
    rust!!!!!!!!!!
    soak it down a few days with a good penetrant.. try loosing the outside nut first (Reverse threads I think)
    If you can't get that inner nut out you'll have to weld a rod to it to get it to break free I think.?
    keep us posted. I should have some pics posted on here when I did my swinger. u may find something useful if you search.
    mmiguy2103's Avatar
    mmiguy2103 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2009
    Fairport, NY
    152
    lmao yea i have seen this many times. the swingarm bearing are one of the most over looked maintence parts on your trike. your going to need heat and lots of it. and a BIG F%&$ing HAMMER. and some punches. if its soo bad it might have to be destroyed to get it out. i hhave had to cut many out befor cause they were too rusted for heat to do anything.
    keep in mine that the pivit bolt and the lock nut are only about $42 online.
    "Advice is Free, The Right Answer will cost you"
    Mar 2007
    Texas
    5,045
    you could consider using staged drill bits and start drilling it out 1 size at a time.\
    it'll be expensive if you don't have drill bits that big already.
    also talk to a local shop. maybe they'll remove it for a $100 fee on both sizes. trust me that $100 is way better than the time and effort your about to spend.
    ________________
    https://www.mikesatvfix.com
    Dec 2005
    USA
    71
    I bought a socket set that included the 17mm allen, something like this:
    http://www.harborfreight.com/cpi/cta...emnumber=98229
    $15 is not bad.
    Aug 2005
    Lockport, NY
    2,395
    You need this tool from honda.
    Not a big punch, or a big ...
    ^ As much as I love you Fro......
    I've only had to take a few of these off in my life and Mr Punch works just fine Then again, you have to know what hurts and what helps
    If I could actually make ANY MONEY working on things!!, I'd buy plenty of these nice proper tools
    Honestly, without heat, IDT that puppies gonna budge myself.........
    Mar 2007
    Texas
    5,045
    where can I get a set of those tools? I like collecting tools!
    ________________
    ^ Awwwwwww, sorry bud but you have to know how to use them .......
    Oct 2006
    North Tonawanda, NY
    343
    Where do I get one of those tools? The book said I would need one, but I never thought they would still make them. Hook me up
    84'YTM200 (sold 02)
    85'KLT160 (sold 05)
