Results 1 to 3 of 3
Thread: Brake Problems
    Aug 2009
    Newfoundland, Canada
    915
    Brake Problems
    How do you free up a rear brake arm lever. mine is seized solid, it can be used as a second foot peg. I tried hitting it up and down but it will not move an inch. any ideas?
    bonkers_200s's Avatar
    bonkers_200s is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Middletown, NY
    393
    Take the tire and hub off, unscrew the drum praying to god you don't ruin the two screws holding it on, pull off the pads, line up a referance mark to help putting it back on and take off the brake lever, using a soft sided pound out the shaft ever so gently, clean it all up, lube it up and put her back together the same way you found it.
    Spray the snot out of and let soak, every nut bolt and the shaft prior to wrenching on anything with wd-40, pb blast, ect...
    Good luck
    If you can't fix it with a , its an electrical problem.
    85 ATC 200s--Ratted out and not running at the moment
    86 ATC 200x--All stock other than the handle bars
    85 ATC 250es Big Red -- Just got new rubbers and she wants to ride!!
    04 Suzuki LTZ250 quadsport - It was a decent price and I'm a raging idiot.
    Aug 2009
    915
    thanks, I will try that when I get her running.
